quick question about vacuum shifting??
Old 01-24-2006, 06:17 PM
firebirdls1us's Avatar
Default quick question about vacuum shifting??
can anyone tell me once you have your tranny changed over to vacuum shifting...just what else in the tranny works off of electronics.......the reason I ask is for converter reasons..and also shift points
Thxs.
Old 01-24-2006, 09:37 PM
LS1Queen's Avatar
If you are talking about vacuum modulation it only controls line pressure
Old 01-25-2006, 04:27 PM
ok thxs....... so with what your saying even though it's vacuum shifting I can still raise or lower my shift points am I thinking correct?
Old 01-25-2006, 05:00 PM
BAIN's Avatar
Yes the computer still controls the shiftpoints.
Old 01-25-2006, 05:48 PM
Rock-On's Avatar
And lock-up...hope this Helps Dave
Old 01-25-2006, 06:51 PM
cablebandit's Avatar
i wonder if my 4l80e will be vacuum modulated?
Old 01-25-2006, 09:40 PM
Rock-On's Avatar
sure why not....hope this helps......Dave
Old 02-07-2006, 04:38 PM
Mssingkid's Avatar
I hope i'm on topic, but if i was to install a Stage 4 or 5(Rock-on) with Vacuum modulation, would i need to change any line pressure peramiters with HPTuners, or would i be able to just install and go?
-Joe
Old 02-07-2006, 04:46 PM
Rock-On's Avatar
Install and go....hope this helps ...Dave
Old 02-07-2006, 07:10 PM
thats just whatI'm going to do rock-on level4.......... this has been the third time my tranny has went down since I bought my car in early 2000...... I keep hearing about the rear but I'm still running the stock rear but with 3.73 richmond gears and so far haven't had any problems with it .just the tranny
