Tranny install problems .. !
Man, im am sooooooooo pissed.
finally got my tranny installed and yeah it is making noises, like a loud valvetrain sound... it wont go into gear. im just soo. tired . cant think straight .
If its the converter . not seated right .. I took a square it it had a inch "and some" . from the square
help !
help !
Where did the tranny come from? It sorta sounds like the same noise that mine had when i broke the tabs off the rotor on my front trans. pump. If you have a tranny cooler pull one of the lines off and start the car to see if your getting any fluid flow.If not then it is definitly a pump problem.
