700R not shifting
Old 02-19-2006, 08:29 PM
STALL UP's Avatar
Default 700R not shifting
My brother has a 91 GMC 1500 with a 700r and it will not shift out of 1st gear. Park ,rev and 1st works but nothing else, does anyone have any experence with these trannys that could help. thanks Phill
Old 02-19-2006, 09:54 PM
Restricted User
Automatics's Avatar
If this happened all at once, then it is most likely a stripped or broken governor gear.
Old 02-20-2006, 12:43 PM
STALL UP's Avatar
I replaced the speed sensor in the rear of the tranny and the old one was covered with metal shavings. Where is the governor gear located? thanks phill
Old 02-20-2006, 05:00 PM
8a8mfh's Avatar
Sounds like a failure inside causing metal to circulate and making the governor stick. Seeing how the speed sensor was covered in shavings.
I'd drop the pan and check.
Old 02-20-2006, 05:09 PM
Greaseymec's Avatar
The govenor is under a cover just foward of the speed sensor. Remove the dome shaped cover and simply grab the govenor and pull it out. The gear is plastic and I have seen a few chewed up. If its bad just go get another one and slip it back in. Good luck.
Mec
Old 02-21-2006, 03:32 PM
STALL UP's Avatar
I checked the governor gear this morning and it looked like new so I guess it is something internal and will have to go to the shop. thanks for yalls help
Old 02-22-2006, 09:43 PM
GOT8?'s Avatar
Will it shift if you move it to manual second or manual third?
Old 02-23-2006, 07:31 AM
STALL UP's Avatar
No I tried manually shifting and It still would not work.
