How to fill Trans Fluid ??
Old 02-23-2006, 07:13 PM
RahuL's Avatar
Question How to fill Trans Fluid ??
Ok, I feel really silly asking this but my TA is a bit low on Trans Fluid... So, I went and bought a couple of quarts of ATF Dex III ... But, call me blind, but I couldn't locate where to fill it from ? Is it where the Trans [red] Dip Stick is ?
Help!!
Old 02-23-2006, 07:18 PM
GreekGator's Avatar
Dont you have to drop the pan in an A4?
Old 02-23-2006, 10:03 PM
RahuL's Avatar
Drop the pan to top-off the fluid ?
Old 02-23-2006, 10:07 PM
00'WS6Rocket's Avatar
get a funnel and fill it where the dip stick it
Old 02-23-2006, 10:08 PM
FLT
FLT's Avatar
quote-Is it where the Trans [red] Dip Stick is ?
Answer is YES!!!!
yes the red p.o.s. thats hard as hell to get off (at least on mine)
Old 02-23-2006, 10:14 PM
RahuL's Avatar
Thanks man!!! !!.. that's what I thought but didn't wanna screw up the aging tranny!!
And yes, the dip-stick is a PITA!!
Finally, does the car have to be idling hot when topping off the fluid ?
Old 02-23-2006, 10:22 PM
05gto60's Avatar
no, it doesnt have to be ideling to fill it. but when you check it, the car needs to be running and have been driven a few miles
Old 02-23-2006, 10:27 PM
SgtB's Avatar
Help!!
with the mods in your sig you have to be kidding me.
that is not true either...it just needs to be shifted through the gears R-N-D-N-R a few times and the fluid will flow through the valve bodies and be good to go.
Old 02-23-2006, 10:35 PM
slowpoke96z28's Avatar
you know to check it after you've been driving for a while, right?
Old 02-23-2006, 10:40 PM
RahuL's Avatar
haha!... yea I've never had to top off tranny fluid before in this car... I've been checking it at reg. intervals, but this is the first time it's a bit low...
Old 02-24-2006, 12:14 AM
wamp42's Avatar
Mine has a lock on the fill. It seems VERY hard to get out. Do I really have to pull harder until it comes out. I unlocked it too and it still doesnt want to come out on my car. Am I doing something wrong or not doing enough?
Old 02-24-2006, 01:42 AM
'Trust''s Avatar
You just need to pull really hard to get it out, once you plug it back in it will come out easily until it gets warm. There are 2 levels on the stick, HOT and COLD, its best to drive it and see where the fluid is at in relation to the HOT mark.
Old 02-24-2006, 09:24 AM
you could always put tranny fluid on the rubber piece so it's a little easier while checking it, but it will be tough again next time.
Old 02-24-2006, 10:09 AM
RahuL's Avatar
the dip stick on my TA has 3 levels:
1 - 80 Degree Mark
2 - Warm
3 - HOT
I'm gonna add about half a quart [ sits at the WARM level when HOT ] and drive a bit, and check again..
Old 02-24-2006, 10:45 AM
just don't put too much or it will lose its vasicity (or something )
