Can a 94 CAPRICE Tranny fit in a 94 Trans AM?
Old 02-24-2006, 01:46 PM
DeCoTo82's Avatar
Exclamation Can a 94 CAPRICE Tranny fit in a 94 Trans AM?
Just wondering because I blown my Tranny on my 94 Trans AM its a LT1 Engine too, but just wondering if a 1994 4L60E transmission from a caprice would fit? PLEASE HELP
Old 02-24-2006, 04:56 PM
FLT
FLT's Avatar
The caprice trans will work fine. However you must swap the tail housing and the cooler fittings. Other than that your good to go!!!
Feel free to call me if you have any other questions.
Vince.
Old 02-24-2006, 05:16 PM
DeCoTo82's Avatar
Hey thanks for the quick reply, I thought it might fit. Only thing now im wondering is how hard is it to swap the tail housing and the cooler fittings and where would I get them and how much? i'd call u but don't got any phone I could use...
Old 02-24-2006, 07:31 PM
FLT
FLT's Avatar
Just take them off your old transmission. The tail housing is just four bolts and the cooler fittings!!!! DONE.
Vince
Old 02-25-2006, 02:44 PM
DeCoTo82's Avatar
Smile
Hey thanks again, that sounds simple enough, but what about the bell housing is it the right size to fit in my Trans Am? And when I go to take off the cooler fittings what am I looking for? Thanx
Old 02-25-2006, 03:07 PM
FLT
FLT's Avatar
Yes your bell will work just fine. As far as your fittings, remove the cooler lines from them, remove fittings from the case and then transfer them to the other unit. Reason being is that the caprice uses larger cooler lines and thus different cooler fittings.
Your welcome, Vince
Old 02-25-2006, 03:37 PM
DeCoTo82's Avatar
Vince thanks for the quick reply, Your good...I can see you've been in the business for a while...oh yeah does it matter if the Caprice is a V6 or V8, I mean its a 4L60E Tranny so i dunno if they put those on V6's or only V8's...and if it came from a V6 Caprice would that affect my Trans Am since its a V8?
Old 02-25-2006, 08:12 PM
FLT
FLT's Avatar
Yes it is possiable. I need the trans code of the caprice unit. It is either located on a sticker on the drivers side top of the bell housing or stamped on passenger rear side of transmission case. Sorry I thought the donor unit was from a V-8. It should start with a 4 and then 3 letters. Such as 4BFD,4BCD,4BBD,4BWD or 4BCD. Get that and I'll set you staight.
Old 02-25-2006, 10:54 PM
DeCoTo82's Avatar
Vince no u were right, I asked the guy I bought the Transmission from if it was a V8 and he said yes it was a 350. Here's a link to the Tranny I bought, tell me wat u think.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8040580645
Old 02-26-2006, 08:26 AM
FLT
FLT's Avatar
Looks like the right case and everything should work just fine.
Good luck, Vince
Old 02-26-2006, 08:52 AM
TeamTripp's Avatar
B-bodies & F-bodies of this vintage share the same case. This case is a modified version of the fullsize 4WD case. Like mentioned above, you can just swap the tailshaft housing and cooler fittings. Both transmissions use the short shift shaft, so even that won't be a problem.
And since the transmission came from an LT1 B-body, then it already has the corvette servo as well. Sounds like you did good.
Old 02-26-2006, 10:15 AM
DeCoTo82's Avatar
Smile
Thanks alot guys, you guys have been great, if I need anymore help you guys will be the first I come to, thanks again...
Quick Reply: Can a 94 CAPRICE Tranny fit in a 94 Trans AM?
