Problem with my 4l60e.....burning fluid, and a vibrating
Old 02-26-2006, 11:24 AM
z28C4maro82z's Avatar
Default Problem with my 4l60e.....burning fluid, and a vibrating
Hey guys need some help
I'm burning trans fluid, that's a problem right there. I have to try replacing the fluid, the filter, and the gasket see if that helps. Other than that no leaks no nothing. I've checked the rear main seal so that's not an option.
I also have this vibrating problem
Now it does it on harder accelerations. I've also noticed it do it when in D....foot on the brake....and getting ready to raise the RPM's to do a burnout. It's really bad when this is done. I'm really lost on this problem
The vibrating I have checked the weights on the DS they are all there. I've checked everything I can think of.
Thaanks for your help everyone.
Chris
z28C4maro82z is offline
Old 02-26-2006, 11:19 PM
Anyone, someones gotta have some input here???
Old 02-27-2006, 11:23 AM
No one has any response to this thread.
Come on guys
Old 02-27-2006, 11:52 PM
rjkZ28's Avatar
hey man i sorta have the same problem. i was told the buring trany fluid was becuase i have a led foot, and the vibration was normal for our cars, i dont know if all that is true, so if someone else has some input that would be nice!
rjkZ28 is offline
Old 02-28-2006, 02:57 AM
Yeh bullshit it's normal lol.
Anyways, my car never did it before. Now it is.
As for the vibration.....not sure exactly, but mine never did that either
Old 02-28-2006, 04:57 AM
Dustin 98TA's Avatar
What do you mean by burning transmission fluid? Does it have a brown color and smell burnt? Is it full?
The vibration sounds like converter chatter.
Dustin 98TA is offline
Old 02-28-2006, 02:02 PM
bump!!!! Help
Old 02-28-2006, 03:05 PM
joecar's Avatar
Burnt fluid (as Dustin said, brown color, smells burnt) is caused by internal slipping, and this is probably the vibration you feel (slip...grab...slip...grab...).
The internal slipping wears out friction linings on clutches and band, and generates heat which fries the rubber seals and further deteriorates the friction linings, which allows more slipage...
joecar is offline
Old 02-28-2006, 05:38 PM
rjkZ28's Avatar
yea i was thinking about putting a deeper trans pan in my car to help pervent heat, i already have a b&m trans cooler so i know that is helpin alittle bit. my fluid is just dark not really burnt, more like really dirty. mine never smells burnt, and it doesnt slip grab slip grab like you are saying.
rjkZ28 is offline
Old 03-01-2006, 01:29 PM
Does not smell burnt nor does it look burnt. I jsut got it changed and we will see how it goes from there. Also I think the vibrating may be a bad yoke or u-joint. Going to try to replace those if anyone think that's what it could be
Old 03-01-2006, 01:34 PM
Added:
The vibrating occurs in 1st around 1200 RPMs and 2nd around 1900-2000 RPMS when powerbraking.
Old 03-02-2006, 05:00 PM
stange567's Avatar
yea mine does the same, i just changed the harmonic blanancer/pulley and that helped out some of the virbation, now its not so bad at all.
stange567 is offline
Old 03-02-2006, 05:05 PM
rjkZ28's Avatar
sorry i ment to post that under my user name not my buddies
rjkZ28 is offline
Old 03-03-2006, 10:10 AM
Checked the pullies......Don't think it's that
Old 03-03-2006, 01:01 PM
The problem with the vibrating has been pinpointed!!!!!!!!!!!!!!!!!
Broken motor mount. My damn engine lifts like a ****!
Anyways, the tranny fluid still looks good too, so we'll see maybe I'm in the clear
Old 03-03-2006, 01:26 PM
Roarin_8's Avatar
Wow, hope all is well now Chris. Put some poly mounts in there.
Roarin_8 is offline
Old 03-15-2006, 02:40 PM
JB00SS's Avatar
So did you get the motor mounts installed and is everything ok now? my car is vibrating also and just wanted to check with you to help me pinpoint my problem.
Thanks,
John
JB00SS is offline
Old 03-21-2017, 11:25 PM
Christopher Meyers's Avatar
Check the wiring harness just did my transmission sensors ND it seemed to help the shifting as well as the control on the drivers side of the pan they have a kit on ebay to replace all electrical components the vibration I have to ND can't figure it out
Christopher Meyers is offline
Old 03-21-2017, 11:26 PM
damn i just payed an arm ND leg to have mine done ND it still lifts wish I read this before hand
Old 03-22-2017, 12:32 AM
Pontiacerator
RevGTO's Avatar
Okay, I think this is enough. We can lay this one to rest now after eleven years.
RevGTO is offline
Quick Reply: Problem with my 4l60e.....burning fluid, and a vibrating
