4L60E and Royal Purple ATF
Old 02-27-2006, 12:54 PM
ExceSSive's Avatar
Question 4L60E and Royal Purple ATF
Has anyone heard any bad things happening or contraindications to using synthetic tranny fluid or royal purple in the 4L60E or any electronic GM transmission?
I just bought 12 quarts of Royal Purple for my trans filter change and TC install...and someone on another site said that the synthetic will make my bands slip of some sh*t.
Any thoughts or experience will be very appreciated.
Old 02-27-2006, 11:45 PM
Board Certified Idiot
Z2K_MrJ's Avatar
I have used it in my last 2 previous camaros i have owned . And currently run it in my New camaro Now. I have never had any problems with anyof them. fluid allways looked Fresh as the day i put it in. All 3 were A4.
Old 02-28-2006, 02:00 AM
BlackHawk T/A's Avatar
Chuck @ FLT (who built my new trans) said I should use Dexron III. He didn't really say anything bad about synthetics other than they don't really like them.
Old 02-28-2006, 08:52 AM
ExceSSive's Avatar
thanks for the input
Old 02-28-2006, 05:26 PM
00 N20 T/A's Avatar
I have royal purple in my transmission, I am gonna flush it out. After i put it in I did a couple of WOT shifts while the car was still a little cold and and it slipped on the 1-2 shift. It only did this two times, so not 100% sure if it is the fluid or what. Just my .02
Old 03-01-2006, 02:07 PM
F-Body Garage's Avatar
I have had Royal Purple in my Trans and never had any issues with it....
Seems to work well for me.
Old 03-01-2006, 02:41 PM
One Bad Z's Avatar
Its good stuff. It might void the GM warranty though.
Old 03-01-2006, 06:14 PM
ExceSSive's Avatar
My warranty has been out since June...
Old 03-03-2006, 05:55 PM
maddboost's Avatar
Most builders do not like synthetic trans fluids because they are usually too "slippery" and can cause the clutches in the transmission to slip and burn up.
Old 03-03-2006, 06:36 PM
chipz's Avatar
I used it in mine with no problems
Old 03-03-2006, 06:46 PM
Drew778's Avatar
My trans builder doesn't like synthetic fluid either, but he did tell me to use Castro type F, so that's what I've been using
Old 03-03-2006, 07:25 PM
slimcracka's Avatar
i would agree i was told by a number of tranny builders and one that works for Gm that you should only use dex..III none of that fancy stuff..i would take taht expensive stuff back and just get some ole regular shyt.
Old 03-03-2006, 10:09 PM
TJ
TJ's Avatar
dextron III or higher as i posted on RP. (stage20)
syn oil in a 4l60 is asking for trouble if you beat on it.
its not good for it shifting regularly.
time bomb.
Old 03-04-2006, 10:04 AM
C5XTASY's Avatar
Yank told me the same thing.
Ed
Old 03-04-2006, 07:26 PM
FLT
FLT's Avatar
Dexton-III is OEM and works just fine.
Quick Reply: 4L60E and Royal Purple ATF
