4L60E Guru needed!
2nd fastest 5.3 ECSB
4L60E Guru needed!
When i do a WOT 1-2 shift i hear a squeel or squeek coming from the trans. It's a short and sharp squeek that happens as it slams into second gear. Only happens during WOT or almost WOT.
I was told this was the bands and not indicating any problem or causing harm to the trans.
Anyone else hear anything like this?
I have seen this happen in the past (many years ago), and it seems that it was the fluid that caused this if my memory serves me right. There have been different types of band/clutch material that can cause this also, but I would not necessarily worry about it, just change to a different fluid. If you know what fluid you are running now, that might be of help?
