shift firmness vs. shift kit
hey guys whats the difference between the 2. i called a local performance shop and like most of them, they dont install shift kits. but they said that you can adjust the shift firmness or what not on a dyno tune!! but i still think getting a shift kit is better correct?
The Trans-Go "modified" Shift kit can give you smooth 1-2 part throttle shifts, and with the shifts getting firmer with more throttle opening. This is better than the electronics can do by itself. The electronics can raise line pressure at part to medium throttle & not much more. The Shift kit can raise line pressure, give more volume of oil to the band/clutches at the right load. The Shift kit when installed correctly will give you more than the electronics ever could by itself.
Pontiacerator
