transmission acting weird
I have a 93 z28 A4 with 107xxx miles,the transmission seems to shift fine,it never over revs,or downshifts on its own,or anything like,but when i shift from park to D,its kind of a hard shift,and sometimes when it shifts from 1st to 2nd when its in Drive its a hard shift, is the tranny going out?? could I need a new tranny mount??
Originally Posted by AceHaag
does it do it when it is cold or all the time
it you changed the fluid resently that my be part of your problem because off the shelf fluid is a little different than factory fluid it has a additive package suited for a wider range of transmissions (friction additives for some ford tannys), but not to worry a stiff shift is good because the clutches slip less unless it is so hard the tires are braking loose then it might be a slight calibration problem. in that year car it is an all electonic tranny. right?
