top speed runs without shifting into 4th...
How is it possible to get a 3.23 to go 140+ (4th gear territory) without a WOT shift from 3->4? Can I just ease into the throttle so it doesn't downshift to 3?
I think he wants to avoid going into OD. If the car is shifting at 5500, you will go into 4th at 130 like 8a8mfh said. If you program the car to shift at 6000, you'll go into 4th at 142.
This site will help you out.
http://www.f-body.org/gears/
Originally Posted by Roarin_8
It sounds like he wants to get into 4th without going WOT. The problem is the paper clutches, they will wear out quickly and 3-4 will be gone due to excess heat and wear.
Originally Posted by 8a8mfh
The 3-4 shift only applies the band, the clutches are already engaged.
s346k is correct! He is trying to avoid the 3->4 shift, this is what kills parts ... the shock of high revving parts and then a gear (shift) change is the killer. He (mpe488) is asking if while in 4th gear, can he ease up to 140 MPH, with enough throttle to avoid the 4->3 downshift. The answer is yes, you can ease up the throttle in 4th gear and reach 140+ MPH.
sorry I kinda forgot to come back and I had you guys guessing what I meant, flame thrower is indeed correct. And I guess I got my answer so thanks everyone.
Then why do I see constant threads where people burn their 3-4 clutch packs and people saying it's because they go WOT into OD or are in OD and do a WOT downshift into 2nd?
