th400 speedo set up anyone??
Restricted User
I had to get with Rossler for my TH350. He takes the tailshaft (9") for the trans and weld in a VSS Bung and bolt tap welding closed the gear driven hookup. Mine was as simple as remove stock tailshaft housing, remove speedo gear, tap on the VSS Wheel, slide the new housing end on, and bolt down, bolt in the VSS and done.
Originally Posted by Strahley
Got a link for a walkthrough on how this can be done?
