Are there 2 different lengths for the TH400?
Old 03-11-2006, 12:23 PM
Silver Slayer's Avatar
Default Are there 2 different lengths for the TH400?
I have read about a short and long tail TH 400? Can anyone confirm this?
Does anyone know which one will work without modifying the T56 crossmember?
Thanks,
Kevin
Old 03-11-2006, 12:31 PM
Pontiacerator
RevGTO's Avatar
Yes, the long tailshaft units were used in the big "B-body" cars. Short tailshafts in A-bodies and F-bodies. Check the thread below ... https://ls1tech.com/forums/automatic-transmission/465992-anyone-know-size-th400-short-tail-driveshaft.html.
Old 03-11-2006, 02:20 PM
cablebandit's Avatar
yes...i have a longshaft th-400
Old 03-12-2006, 03:25 AM
Restricted User
Automatics's Avatar
There are 3 different lengths for the TH400.
Old 03-12-2006, 05:47 AM
Do they all have the mount in the same location, with just a longer/shorter tail?
Old 03-12-2006, 07:50 AM
no...they are different...look here
http://www.tciauto.com/tech_info/trans_dims.htm
the first 2 are commonly called short/long....i dont think many people use the really long one
Old 03-12-2006, 08:12 AM
Damn.. That is exactly what I needed!! Thanks Jerry.
It is only a 1" difference between the mounting points in the two most common tailshafts, so I guess it wouldn't matter which crossmember I used, I may just have to slot the hole for the mount a little.
