Fuddle 32-3400 VS. Yank SS4000 results
2-10-06 Yank SS4000 2.6 STR 11.5x26-15 ET streets
1.737 7.540 92.39 11.799 115.75 N/A
1.670 7.437 92.39 11.697 115.67
1.608 7.327 93.76 11.551 116.25
1.561 7.225 94.27 11.420 117.16
1.544 6.875 100.44 10.802 125.06 100 shot
1.559 6.857 101.55 10.738 126.33 150 shot
1.573 6.891 101.12 10.775 126.28 150 shot
2-11-06 Yank SS4000 2.6 STR 11.5x26-15 ET streets, skinnies - removed muffler
1.614 7.256 94.56 11.424 118.05
1.621 7.226 94.96 11.368 119.00
1.577 7.193 95.50 11.332 118.97
1.564 6.937 99.12 10.921 123.21 150 shot empty bottle
1.583 7.065 97.62 11.088 122.26 75 shot full bottle
3-10-06 Fuddle 32-3400 2.1 STR 11.5x26-15 ET streets, skinnies
1.750 7.579 92.63 11.874 114.17 N/A
1.668 7.489 94.31 11.763 115.08
1.659 7.201 97.41 11.254 121.29 75 shot
1.625 7.004 100.21 10.936 125.30 100 shot
1.642 7.229 92.20 11.747 106.58 150 shot blew head gasket
So I lost 4 tenths and 4 mph going to the Fuddle, around the same with nitrous, but the converter is much tighter, maybe it need more miles?
Originally Posted by BlackHawk T/A
Why did you switch?
Well, the Yank was kind of loose for me and the Fuddle was supposed to be better with nitrous?
But this was only one night with the Fuddle, my first night with the Yank I wasn't impressed either.
well i think it did good comparing apples to oranges.. goin from a 2.6str to a 2.1 and loosing 400~600 rpm in stall im suprised it did that good..look at the N\A pass.. a fair camparo would be a 4000 vs. a 4000 just my .02 but good times nontheless!
Restricted User
Andrew, I agree on needing more seat time with the fuddle. I do recall when you went to the Yank you bitched and moaned about it for two three w/e's, then all of sudden one day you ran a NPB and it was the greatest TC on the planet. Give your car a new head gasket, which I'm sure hasnt been leaking one run, more like the whole time the fuddle has been in, and give it some more go-go later.
There's no way you're car's making better power at 3200-3400 than 4000. The results look great when you think of it that way. I'd actually like to see the bottom 10's that a 4400 could have probably gotten you.
Long live 10 line signatures...
Couldnt agree more
Restricted User
1 Nitrous gets a bigger torque spike at lower rpm, some ppl are fine with this where other will design their combo to only arm higher in the rpm range.
2 On the bottle, stall is closer to 4000 than 3200, whereas with an NA run it should be right close to 3200. Its all dependent on how much torques is produced and what RPM?
2002_Z28.....yes there is a good reason, as stated above. You definately do not want to launch a 5100 stall car NA and then hit it with a 250 shot, youd have fun picking up the pieces unless all the components inside where fine with a 6000+ rpm launch at that amount of torque. Also, if the higher stall TC is not efficient, due to age, design or wtfe, then a newer, more efficient TC can be more than worth it.
Damn, now I motivated, I'll post some new times next weekend.
If everything will stay together, I'm sure I can beat my 150 shot Yank SS4000 10.7 time with this new Fuddle and a 150 shot.
Either way he was sold a product and told it could do something it couldn't.
Originally Posted by 2002_Z28_Six_Speed
Obviously, that is not what was happening or he wouldn't have been able to run that Yank converter for that long. Yank builds the converter with your HP in mind and the rating is pretty accurate. Efficiency is determined by the experience of the builder and quality of the parts AS WELL as the research into them. A higher stall converter is just as efficient % wise at the coupling RPM. You really have to test each converter rather than using general rules. Not all brands are equal!
This was just the first try, I'm not giving up yet, I was just sharing my results.
Stay tune it's not over yet
I'm able to cut the times in my sig on a VIG 3200.
With a smaller stall and nitrous, a proportioning valve is a great asset to be able to brake stall closer to actual stall flashing point.
I cut 1.4x on 150 dry
Restricted User
Do you use nitrous? Do you know that the lower the RPM the more torque it builds? Do you know some ppl set their heavy *** cars up for higher torque at lower rpm launches for a reason? Efficiency has little to do with the builder period. It has to do with the internal components of the TC, bottom line. You can alter the pitch of the blades and the TC will act totally different, change the sizing of the impeller or vanes, etc etc, just cause it has XXXXXXXX name on it doesnt mean ****. If it did, then everyone would have a Yank. FWIW I used to own a Yank, and have installed a few, to include the one just removed from Andrew's car, so I have some experience with them. Have a nice day.
Oh lest I forget, yes time can effect the results. You dont see how? Try launch technique, effects of DA, tuning and general seat time.
Charlie
