How to tell what stall you have
Old 03-16-2006, 12:19 PM
SEB
SEB's Avatar
Default How to tell what stall you have
Just picked up a 2000 Formula & was told the stall was a Yank 4200, But I don't believe everything I am told. Would like to klnow for myself. Is there anyway to crawl under the car & look to see what kind of converter I have with out pulling the transmisson?
Old 03-16-2006, 12:22 PM
BlackHawk T/A's Avatar
It should be on there if it is a Yank. Here is mine.
Old 03-16-2006, 12:26 PM
SEB
SEB's Avatar
But is there away to verfy that it is a 4200 while it is installed in the car without pulling the transmission.
Old 03-16-2006, 12:36 PM
s346k's Avatar
put it in 2nd gear...torque it up.
that will tell the true stall speed, as it will stall (usually more than advertised by a couple hundred rpm) before totally igniting the tires.
my 4k stall brakestalled in 2nd gear to ~4200.
Old 03-17-2006, 01:43 AM
2002_Z28_Six_Speed's Avatar
If it is really important you can still get a peak at the TC if the car is on a lift. How else can you get the TC bolts in if the trans and engine are together.
Old 03-18-2006, 08:50 PM
Mazzenger's Avatar
There is a 2-3 inch diameter circlular piece of metal that pops off with a screw driver that is on the bottom of the tranny (at the very front of the tranny) Pop it off and look up in there. Converter should be red and have a sticker on it saying what the stall is. You may have bump the ignition key a few times to get the converter to turn and show the sticker. You can do this in the drive way while it is on ramps.
Old 03-18-2006, 08:59 PM
chrs1313's Avatar
my yank was a custom str 2.2 so mine didn't ahve that sticker but it should be red, mine stall size was engraved with a pen, just fyi on the yank
Old 03-18-2006, 11:30 PM
When I ordered one is 2002 it was red, had one skinny white and black label saying what it was, and one silver metallic yank sticker beside the white and black one. Since they switched to the circular sticker around the pilot I don't know if they stopped the metallic sticker.
