Trans stuck in 3rd????
Old 03-19-2006, 08:02 PM
SgtB's Avatar
Exclamation Trans stuck in 3rd????
So I took the car out for a ride today.
I threw a code P0121..Throttle Postioning Sensor. I replaced it a couple weeks ago but I have only driven the car maybe 3-4 times.
First off, I have a 3500 Fuddle and the trans is vacuum modulated.
Anyway..I was pulling up to a stop and the car died. I restarted the car and the trans feels like it's stuck in third. I say that because it feels like I when I pull away from a stop the car revs(like a normal car with a loose converter) but has no power. It never shifts..and then when I cruise at 60mph I am at 2500 rpm's...The car is shaking real bad too at a stop sign...worse than normal with my cam(236 @ 050 .585 lift).
Any ideas???
Old 03-19-2006, 09:52 PM
yak
yak's Avatar
man that sucks, hope you get it worked out. It may just be in the trans, did you try manually shifting it to see if it would come out of gear? sometimes my car will not downshift even under wot. it is weird, it will just sit in third gear and try to pull. Looks like we both may be looking for an answer. m however if this is the case I think it is a computer issue rather than a trans issue considering I just put a new trans in my car, but it still acts up occassionally.
Old 03-19-2006, 09:53 PM
SgtB's Avatar
no, I havent tried dropping it into first...too late to take it out now. I will take it for a ride in the morning and see it it make a difference.
My trans has less than 1k miles on it too.
Old 03-19-2006, 10:00 PM
yak
yak's Avatar
give flt a call chuck should be able to help you out, they are top notch.
Old 03-19-2006, 10:08 PM
SgtB's Avatar
I will see how it reacts to manual shifts tomorrow and then the give them a call.
Old 03-19-2006, 11:11 PM
Moderator
jimmyblue's Avatar
Read up on what that code means. I think your cam wants
some tune changes to settle that code down, it hassles
other things since the TPS is deemed unreliable (wrongly).
Old 03-19-2006, 11:15 PM
BubaGumpShrimp's Avatar
check to see that you have the p0757 code shut off. I had the same problem you described (being stuck in 3rd) right after i put my 3,800 fuddle in. Thought i toasted the trans.. If the computer see's the converter is slipping too much (still thinks the stock one is in there) it will set the p0757 code and lock you out of certain gears, for me it was everything except 3rd. Do a search under my screen name and look for p0757
Old 03-20-2006, 07:54 AM
SgtB's Avatar
So, I took the car for a ride this morning. It still has the SES light but the car is driving normal again. Most likely it is a tuning issue then?
