FREE way to get speedo to work in th350/th400.
Old 05-09-2012, 09:19 PM
  #81
robsquikz28's Avatar
man this thread always reappears
Old 06-07-2013, 07:05 PM
  #82
1sick-Z's Avatar
I am bringing this back again. Has anyone just found the pin connectors that go to the computer and you can just link them up there?
Old 01-20-2014, 10:45 AM
  #83
Beave's Avatar
Did this yesterday and it works perfect! Thanks for the info.
Old 02-28-2015, 06:52 PM
  #84
camarols6's Avatar
hi guys
anyone use Rostra Vehicle Speed Sensors 250-4153 from summit
on 4th Generation fbody with th400
http://www.summitracing.com/int/parts/rpc-250-4153/all
Old 09-23-2016, 05:36 AM
  #85
GHOST Z's Avatar
Originally Posted by FTICONVERTERS
Just sayin!!
I have the reluctor wheels, both 40 tooth and the 17 tooth in stock as well as the wiring adaptors and the speed sensors for the TH400
Greg
so if I get a new/the right reluctor wheel can I just hook up the ecu/pcm to the trans and not have to mess with my abs at all
Old 09-23-2016, 07:42 AM
  #86
LS1Tech Sponsor
FTICONVERTERS's Avatar
We no longer have the speed sensors but we still have the reluctor wheels and pig tails. The sensors are only available from PATC and they're not cheap. To answer your question yes that should work.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 09-23-2016, 09:32 AM
  #87
GHOST Z's Avatar
Any idea of any cars that might have this sensort I need in it maybe I can find another one somewhere sone how or I'll just use a cable and a after market speedo it's pretty much an all custom car anyways I just wanTed to keep all my blinker and check enine and wat not but maybe I'll use a custom home made cluster
Old 09-26-2016, 07:50 AM
  #88
LS1Tech Sponsor
You MIGHT get lucky and find one on a junk yard TH400 unit but you're rolling the dice on it working or not.
__________________
1-866-726-8358
FTIPerformance.com
Old 10-02-2016, 12:32 PM
  #89
john kilgore's Avatar
l have a few reluctor wheels and mag pick up stuff for th400 pay the freight and it's yours
Old 02-20-2017, 10:08 PM
  #90
Bama99z's Avatar
Default Speedo
I was told today that I could use a VSS out of a 1989 Chevrolet SS 454 truck and it would allow the speed odometer work correctly. Anyone ever used this and did it work correctly?
Old 02-21-2017, 06:22 AM
  #91
merim123's Avatar
that is where the factory sensors everyone is talking about come from. you may get lucky if you can find some. but you need the reluctor wheel, sensor, pigtail.
https://ls1tech.com/forums/automatic...ed-sensor.html
Old 02-21-2017, 07:29 AM
  #92
LS1Tech Sponsor
We have the reluctor wheels (40 tooth and 17 tooth) along with with the pig tails. you just need to find a good sensor! that's the hard part.
__________________
1-866-726-8358
FTIPerformance.com
Old 02-21-2017, 09:31 AM
  #93
Bama99z's Avatar
Thanks for your help I will be in touch once we decided if my trans has the reluctor wheel in it already.
Old 09-16-2019, 09:58 PM
  #94
Johnny_M's Avatar
Default VSS for mechanical speedo
Dakota digital is offering a vss for auto trans. Swaps from a 4l60e to th350, 400, PG.
https://www.dakotadigital.com/index....rod/prd916.htm
Old 01-18-2022, 02:00 PM
  #95
01CamaroSSTx's Avatar
Received 1,786 Likes on 1,293 Posts
Am I following this correctly? To get the speedometer working when you have a TH350 400 or PG I'm to remove the VSS sensor plug from the harness for the manual transmission and solder in the connector for the right or left front ABS/VSS sensor to it and then plug it into the harness for the front wheel hub assembly? I'm hoping someone who's done this before is still around and can answer this for me. Seems more and more of the people to these old threads don't even post anymore.
Old 01-18-2022, 02:51 PM
  #96
93Z2871805's Avatar
2-wire signals are just VR flying magnet, you just have to adjust for the teeth/tire diameter/absence of rear gear ratio. Front hubs should be 47 tooth.
Quick Reply: FREE way to get speedo to work in th350/th400.
