is the 4L80e better than 4L60e?
Old 04-04-2006, 09:23 PM
98formulaMAH's Avatar
Smile is the 4L80e better than 4L60e?
Is there an advantage to upgrading to the 4L80e? Does anyone do this? Thanks
Old 04-04-2006, 09:34 PM
Spdmini's Avatar
The 4l80e is rated for more Tq in stock form than the 60. Many ppl have upgraded to a 4l80e, Im one of them. Think of it as a T400 w/ OD. there is no downside.
Old 04-04-2006, 09:43 PM
Is there any changes in the car that need to be made? Like any wiring or is it a direct fit for EVERYTHING?
Old 04-04-2006, 10:07 PM
GregWS6&z28's Avatar
converter and crossmember are different, not sure of what else
Old 04-04-2006, 10:55 PM
camaroextra's Avatar
i think its longer so you will prob need a new driveshaft
Old 04-05-2006, 06:49 AM
cablebandit's Avatar
i did a writeup...search for 4l80 or 4l80e or 4l80-e
Old 04-05-2006, 08:36 AM
Z'mnypit's Avatar
Nope stock driveshaft works. Just have to get a different yoke to fit the 4l80e. But then agian Im still on the stock rear. There is a wiring harness you have to buy from speartech, Your PCM will also need changing by HPtuners or someone like that. Its not something you can do yourself, crossmemeber (BMR, Yank), A converter that will fit the 80e & bolt up to the LS1/LS6 flywheel. (fuddle) The trans cooler lines have to be bent at the trans. Im in the process of swaping this out myself as we speak....
Old 04-06-2006, 07:41 PM
ExceSSive's Avatar
Question
Did the Rossler go out???
Old 04-06-2006, 08:18 PM
2002_Z28_Six_Speed's Avatar
Yank sells a crossmember for the 4L80E conversion. Fuddle couldn't have figured out as they don't sell one. Why trust them?
The 4L80E has a slightly diff harness and uses an extra speed sensor over the 4L60E in most applications. It is basically a TH400 with overdrive as previously stated. Very expensive trans to buy from the dealer. They hold up to the late model big block quite well.
Old 04-06-2006, 08:29 PM
Z'mnypit's Avatar
Yep about a month ago. Started slipping in 3 & 4th. IT was an awesome trans really took a beating. I just dont want to be doing this all over agian in almost another two years so its time to upgrade.
Quick Reply: is the 4L80e better than 4L60e?
