Code PO757.
Old 04-08-2006, 01:22 PM
zssman's Avatar
Default Code PO757.
Scanner says, shift solenoid B circuit stuck on. I have a yank ss4000. This started after just driving around town. The idle became very eradic and the car wanted to stall out(die) at every stop. Cleared the code, but the idle is still screwed up. Assistance needed.
Old 04-08-2006, 01:53 PM
2001NBMZ28's Avatar
Search for P0757 - lots of posts on it. Did you just get the TC installed?
Old 04-09-2006, 09:48 PM
zssman's Avatar
Yes changed from a vidge 2800 to a yank ss 4000.
Old 04-09-2006, 10:08 PM
2002covtz28's Avatar
i have the same problem, just installed ss4000 as well, and it does not shift into OD. it was working fine for me the first day then it would stall up real high cause the converter was not locking, then it started working fine for a month and it happened again last night, i think it just has to be programmed for the stall and it should be fine.
Quick Reply: Code PO757.
