Stock auto shifter headache, help!
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Sorry if this is a repost of a similar topic, as I did a search.
The problem on my '00 Formula. The button you push in on the shifter **** to shift from park back to any other gear will not go in to disengage the lockout. Yes I've held the brake down with the car ignition on with the car running as well as key to the on position with the engine off. For some reason it seems to be stuck and not wanting to work. The button comes straight out and I see a white plunger with a spring, and thinking maybe the button is worn out (looks kinda rough in that area).
Anyone else experience this?
TIA,
Derek
TIA,
Derek
