th400 shifting rapidly in 3rd
Old 04-15-2006, 06:33 AM
Dfont's Avatar
Default th400 shifting rapidly in 3rd
I rebuild my Jeep CJ7 from scratch and overhaul the engine. I saw a big difference in the compression. I did not measure it but my battery barely start the engine. it's a good news... and a bad one cause i have to change the battery for a dry one.
since then, the tranny goes from one to 3rd very rapidly, under 30 mph. I suspect there is too much vacume..
Is it the case?
Dan
Old 04-16-2006, 02:37 AM
Restricted User
Automatics's Avatar
What transmission are you running? If it has a vacuum modulator, turn in the screw on the modulator a full turn and see what happens? If this improves it, you can turn it in a little at a time, until you get the shifts where you want at part throttle. Do not turn in the screw more than 4 turns total, as this can possibly ruin the vacuum modulator.
Old 04-16-2006, 08:04 AM
Dfont's Avatar
Default ...
The transmission is a th400. There is no modulator.. Should I install one?
Old 04-16-2006, 09:05 AM
8a8mfh's Avatar
No modulator? you either don't have a th400 or have one with the modulator plugged. BUT if it had a modulator plug it would shift late and hard UNLESS someone set it up like this and put some weak governor springs in it with heavy weights.
All very unlikely.
I'd say you don't have a th400.
Old 04-16-2006, 10:11 AM
chris718's Avatar
is there a cable installed between the throttle linkage and the transmission or any vaccuum source to the trans?digital photo would help.
Old 04-17-2006, 06:53 AM
cws T/A's Avatar
you need a governor recalibration spring kit $25
