help trans
Old 05-05-2006, 01:56 AM
CASHss99's Avatar
Default help trans
we are trien to remove teh auto trans,,,, we have everything detached kuz we are pulling the motor to so
we have only 2 bolts out for the converter kuz we stripped the other allen head bolt and have no ideas how to get that out???? kan the trans be removed with the converter on teh engine still,,, the tran wont budge still
Old 05-05-2006, 07:09 AM
King James's Avatar
It sounds like your wanting to pull the engine and trans as one unit from the top. Correct?
For the stripped bolt, get a small grinder or die grinder in there and grind a side of the bolt flat. Then get a hammer and chisel to try to break the bolt free.
Old 05-05-2006, 07:29 AM
80superbu's Avatar
Maybe you can get a chisel on the edge of the bolt. Smack it a few time to break it loose. Kinda like the old screwdriver through the oil filter removal trick
Old 05-06-2006, 04:41 AM
CASHss99's Avatar
yuh im removing it from the top,,, im werking on the kar 2mawo or sunday so yea i will do the old screwdriver trick, we are getting all new **** i mean everything, so sumthing breaks it breaks,, thanks guys
Old 05-08-2006, 02:56 AM
CASHss99's Avatar
All good we got the motor out with teh trans,,, teh trans was frozen to the pins on the block but after my friend stupidly dropped the transmission side when we lifted the motor it fell off the block so all good
