Torque arm
Torque arm
ok guys i must be real stupid because im not getting this i need a chassis mounted torque arm for my m6 to th400 swap i know i need the crossmember conbersion but where do i find the chassis mounted torque arm i looked at bmr and it looks like the one i need but i see no where on the torque arm where it bolts to the crossmember is it just not shown on the picture on bmrs website it part# ta002 please help.
??? a tunnel mounted torque arm has nothing to do with the tranny crossmember. It bolts to the floor where your tunnel brace was before your header install (I had to remove mine). May I suggest a UMI tunnel mounted torque arm? I am extremely happy with mine. Its only hit the floor maybe twice since I've had it and doesn't vibrate nearly as badly as some others have experienced with the BMR and Spohn TAs.
BTW, you're not stupid (you can't be, M6 -> TH400 equals ), we all had to learn about things at one point or another.
Thanks Kpowr82
The nice thing about a tunnel mounted torque arm is no matter what transmission you are using the torque arm will work just fine. Both of the tunnel mounted arms in the links below will work for your swap, it just depends on what exhaust system you are using. If you need any help send me a e-mail or PM.
http://www.umiperformance.com/2202.aspx
http://www.umiperformance.com/2200.aspx
Hope that helps
Ryan
Hope that helps
Ryan
LS1Tech Premium Sponsor
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
I am running pacesetter lt with the pacesetter y-pipe into a cutout with the stock muffler just so i could sneak up i people lol but thanks for all the info thats what i needed to know later
Darren
Darren
