Manually shifting the 4L60E during road courses
Old 05-14-2006, 01:56 PM
Fast GTO's Avatar
Default Manually shifting the 4L60E during road courses
I went to the Nordschleife for the first time today and was manually down shifting to 3rd and 2nd when dipping into turns.
I was just wondering how detrimental this would be to the trans considering the RPM's shoot to 4-5K and I am planning on pushing the 390/400 rwhp mark.
Would a shift kit prolong the life of my trans?
Old 05-14-2006, 02:15 PM
Fast GTO's Avatar
Yeah, from doing a search it looks like I shouldn't do this on a regular basis.
Old 05-14-2006, 08:53 PM
BlackHawk T/A's Avatar
I wouldn't recommend it. I was told that actually just leaving it in 2nd is what some people do, but I wonder how well you can do being limited to one gear.
Old 05-15-2006, 12:34 PM
koolrayz's Avatar
I believe doing that burns up the over run clutches
Old 09-28-2006, 09:39 PM
OldSchoolFormula's Avatar
Are the overrun cluctches affected if you just leave it in 2nd? Its hard to negotiate good mountain roads when all the damn A4 wants to do is go into OD. Leaving it in 2nd is waaaay nicer to keep in the powerband.
Old 09-29-2006, 06:48 PM
TJ
TJ's Avatar
youre gonna fry it.
be safe.
Old 09-29-2006, 07:11 PM
Alright. So the overruns are engages when just leaving it in second then, or are they only engaged when actually downshifting to match revs of the output shaft with the motor? I see that some guys like to leave it in second during autocross runs.
Guess I need to look for a 6 speed.
Old 10-01-2006, 04:05 PM
Daez's Avatar
Well, you could keep it in third(D), and it wont shift into OD, if OD is the problem.
Old 10-02-2006, 12:01 AM
Pontiacerator
RevGTO's Avatar
Keeping it in 2nd and 3rd is going to keep your overrun clutches engaged, but that doesn't mean it's going to burn them up. Ensuring adequate fluid flow to the clutches and keeping the fluid cool are the key to keeping your tranny alive. Yes, the Transgo will help - especially with the enlarged fluid feed holes in the separator plate - and don't forget a tranny cooler.
Old 10-02-2006, 12:56 AM
staringback05's Avatar
bottomline...a4 shifting
Old 10-02-2006, 03:41 AM
Its not so much shifting, its trying to prevent the damn thing from doing so. I'll take a look at a big tranny cooler and the shift kit if I can be assured it won't kill the transmission. Either way, I hate the way the LS1 4L60's shift. Talk about a slushbox.
Old 10-02-2006, 05:03 AM
Stock, yeah. But there is much you can do about that
Old 10-02-2006, 08:38 AM
Pontiacerator
RevGTO's Avatar
I posted a thread a few years ago "I hate my A4." Now I LOVE it. It's not stock anymore.
Old 10-02-2006, 09:12 AM
PBA
PBA's Avatar
When road racing, and you are going to manually shift the gears, you will need to blip the throttle on down shifts (like double clutching a manual transmission) as soon as the transmission rpm's match the engines (almost immediate) you can let off of the throttle to start the deceleration in the chosen gear. If you do it this way, you should not have any problems here. I would add the larger boost valve at a minimum, or the modified Trans-Go Performance Shift kit. You will need a large external cooler, and go with very good oil here. I have seen Monolec 7500 do very well in 4L60E's when road racing.
Old 10-03-2006, 06:32 PM
04BlackSilverado's Avatar
I know on the trucks we have "Tow Haul Mode" which changes all the shifting points and requirements when we hit the button. It keeps the trans in gear longer for towing, but I love it for tooling around on the street. You can have completely different shift tables for regular and "tow mode". I think just what your looking for. not sure if the car PCM's have this, or if it is in the trans computer.
This may be worth looking into, but I do know that shifting from 4th to 2nd to pass is bad, and manually downshifting is bad.
Good luck, I don't really know too much about the car programming or trans controller, sorry.
Old 10-03-2006, 08:00 PM
onebadblackz's Avatar
I fried mine doing this
Old 10-03-2006, 10:32 PM
BlackZ28629's Avatar
Yeah... I used to run the mess outta my 700R4 in my 87' w/ a B&M shift kit; manually shifting and downshifting.....It was bulletproof, I tell ya...until the whole car was stolen Fun while it lasted, though....The 700R4 and the 4L60E are just about the same thing internally. I wouldnt go manually shifting it like crazy though;especially if it is your daily driver! I guess it just depends on the condition and how well you take care of it.
Old 10-04-2006, 01:30 AM
I'm not really looking to manually shift it, rather just stick it in second and leave it there. With the 3.08's that gives me a pretty good range of speed to play with up in the hiils. I know downshifting hard is bad for the transmissions as the overrun clucthes have to slip a lot, I just dont know how bad it is to leave it in a single gear.
Old 10-04-2006, 01:45 AM
im sure over a amount of time it would burn that gear out...ive never heard of anyone actually just leaving it in one gear, but i really dont think it can be done for any long amount of time
Old 10-04-2006, 01:09 PM
what he said^^^^^
Quick Reply: Manually shifting the 4L60E during road courses
