Helpppp Asap!!! 1995 Transam Auto Transmisson Problem
Old 05-14-2006, 06:05 PM
ZSU
ZSU's Avatar
Unhappy Helpppp Asap!!! 1995 Transam Auto Transmisson Problem
I HAVE GOT 1995 TRANSAM CONVERTIBLE 110000.. I HAVE GOT PROBLEM ABOUT TRANSMISSION...
WHEN I ACCELERATE AND 1ST GEAR OK 2ND GEAR OK TOO, BUT WHE IT COMES 3RD SO 4TH I HAVE SPACE AND NO ACCELERATING ONLY RPM MOVES...
AND TODAY I MAKE MY CAR BURN OUT AFTER THAT WHEN I WHAT TO START MOVING, I FEEL 1ST GEAR HAS A LITTLE SPACE OR SOMETHING..
WHY IT COULD BE?? OR IS IT A BAD THING? OR IT MIGHT BE BECAUSE OF "BURN OUT"??
SOME ONE HELPPPPPPPPPP SOON....
Old 05-14-2006, 06:38 PM
Honda Hunter's Avatar
Take the caps off.
Old 05-14-2006, 07:04 PM
8a8mfh's Avatar
Sounds like the typical 3-4 clutch failure starting. The pause before first might be the forward clutches worn.
Old 05-14-2006, 09:13 PM
DarkFormula's Avatar
3-4 clutches are toast, your forward band is starting to go bad.
BTW, kill the Caps Lock.
Old 05-15-2006, 09:52 AM
ZSU
ZSU's Avatar
Thanks for your interests and answers..
Today I drive my TA and at 1st gear I notice there was nothing abnormal about it.. May be it just be hard pressed because of BurnOut.. I did it 3 4 times.. I am going to fix 3rd and 4th problem ASAP.. but is it a bad thing to drive slowly with 1st and 2nd gear until I leave it to its Service? Because they said it will stay here 3-4 days...
Old 05-15-2006, 09:33 PM
FLT
FLT's Avatar
I believe you meant to say the 2-4 band!!!
Old 05-16-2006, 05:32 PM
Yeah, that too.
<- dealing with a long week
Old 05-17-2006, 12:27 AM
Jimmy P's Avatar
I wouldn't realy daily drive in 1st and 2nd gear only.
Old 05-18-2006, 10:54 PM
thunder95ta's Avatar
I have the same problem, can you just repair the 2-4 bands or do you have to rebuild the whole trasnmission??
Old 05-19-2006, 09:03 AM
ZSU
ZSU's Avatar
the service said that we are going to rebuild whole transmission with new transmission clutches or smth like that
Quick Reply: Helpppp Asap!!! 1995 Transam Auto Transmisson Problem
