Rearend
Old 05-21-2006, 12:09 AM
z28LS1's Avatar
Default Rearend
I have ran my Camaro with excessive backlash in the rear end. The gears wine like its a semi. I was going to just buy a rebuild kit and redo the rear end gears. Right now it's all stock and I have 3.23's from the factory.. I was thinking getting 3.73's.. It's an automatic. It's my daily driver and I was wondering if going from 3.23 to 3.73 would effect gas mileage that much. I use this car on the highway a lot and didn't want to really effect the gas mileage.. What do you guys think?
Old 05-21-2006, 01:23 AM
2000SLPZ28's Avatar
i went from a 2.73 to a 3.42 because i didnt want to kill my gas milage, and its also my daily driver. i wouldnt go any higher then a 3.73 if you are going to drive it everyday. i am very satisfied with my 3.42, i could feel a very dramatic difference. but for you going from a 3.23, you wouldnt feel much of a change. go with the 3.73 and youll get about 260-280 miles to a full tank. thats not coming from experiance but from a judgement of my gear. on the high way i usually get about 300 miles.
Old 05-21-2006, 02:38 AM
8a8mfh's Avatar
I swapped from an automatic transmission to a six speed. Instead of going to the 3.42's I went with 3.73's and drove it with the automatic trans for a while. It didn't feel that much faster because it would break the tires loose easier from a stop. What I really noticed was highway driving, it felt like it wasn't going into overdrive, it was but the rpms were just up, gas mileage got worse.
Old 06-27-2006, 12:11 AM
z28LS1's Avatar
Need more advice on this! Bump Bump! Debating between 3.42 or 3.73 - FROM 3.23... So I might as well go with 3.73 from what everyone says.. I hope my gas mileage is there still... More opinions please!
Old 06-27-2006, 11:53 PM
z28LS1's Avatar
Old 06-28-2006, 12:05 AM
waterbug1999's Avatar
IMO, stick with your 3:23's or 3:42's at the most. You said you do alot of highway miles and you will get tired of the 3:73's.
