# of bolts on 4l60 tranny
Old 05-31-2006, 12:57 AM
love2puck44's Avatar
Default # of bolts on 4l60 tranny
are there 6 bolts or 8 bolts connecting the tranny to the engine???? i got 6 off and the thing isnt comin off. if there is 2 more where are they? and how do i get them off?
Old 05-31-2006, 03:19 PM
Black Soul SS's Avatar
http://modernmusclecars.net/forums/a...p?do=tcinstall
there are 8 of them
Old 05-31-2006, 03:59 PM
calongo_SS's Avatar
gotta unbolt the converter also. Make sure you unbolt the x-member, and let the trans sag down to get at the top bell housing bolts. you will need ~36" of extensions. I use 2 24"'s. first time I had my trans down the dowel pins were seized up and it was a major PITA to get them to let go.
Old 06-01-2006, 12:16 AM
Jammer's Avatar
If you remembered the converter then its the dowels...Mine were seized tooooooo!
Old 06-02-2006, 01:03 PM
ohsofast's Avatar
Oh does two bolts up top are a PITA ,the first time or two you take out you trans. Have fun with that
Old 06-04-2006, 10:54 PM
Jammer's Avatar
unbolt the crossmemebr and let the tranny hang...get a 36" extension and it only takes a minute.
Old 06-04-2006, 10:59 PM
Figz Z28's Avatar
There are 8 bolts.
Old 06-05-2006, 11:55 AM
02 BLK WS6's Avatar
Yep, 8 bolts
Old 06-05-2006, 06:07 PM
smmurf86's Avatar
on my 2002 there were 9 bolts.
Old 06-07-2006, 11:35 AM
mshadow's Avatar
My 98 had 7
My dowel pins were seized baddd...I checked on here everyone said 8 bolts....I took out 7 bolts...looked for a while for #8 and there wasnt.
Old 06-07-2006, 03:29 PM
DanZ28's Avatar
Mine also has 8 bolts. The bellhousing itself has holes for 9 bolts but the block/oilpan will only take 8.
Dan
Old 06-29-2006, 11:47 PM
jtl12419's Avatar
Hi,
I am missing the 2 lower bolts connecting the bellhousing to the oil pan.
One goes thru the bell housing into a threaded hole, the other looks to need a nut on the other side.
What size are these bolts so I can replace them? GM Part no.? What is the torque to tighten?
TIA
Old 06-30-2006, 10:03 AM
DanZ28's Avatar
I think the bolt size is M10 - 1.5 pitch, But I'm not 100%, it's been a while. There should be no nuts used anywhere between bellhousing and block/tranny.
Dan
