converter bolt size
Old 06-01-2006, 02:01 PM
spanky_55amg's Avatar
Default converter bolt size
i will be installing a ssf4400. does it take different bolts to the converter then stock, and if so, what size?
Old 06-01-2006, 08:42 PM
does no one know?
Old 06-02-2006, 05:59 AM
8a8mfh's Avatar
I've owned two street fighters. One used stock metric bolts and one used 7/16 fine thread. When you get the converter you're just going to have to thread a few bolts in there until you find the right ones.
Old 06-02-2006, 09:41 PM
ah ok, tci said it was 7/16 x 20 but this is my buddy's old stall and im not sure he knows what it is b/c he tried like two or three right at the same time...ha ha
Old 06-04-2006, 07:24 AM
1QUIKWS6's Avatar
Stock verter bolt size is 10mm - some aftermarket verters use the stock size - some use the 7/16 size as previously stated. Another factor will be the bolt length - if you are using an aftermarket flexplate such as the TCI with bosses surrounding the verter bolts - you will need slightly longer bolts for proper thread engagement (standard rule of thumb is 1.5x the bolt diameter if possible).
-Jay-
