whats the biggest baddest trans cooler that is affordable?
well im going from a t56 to a th-400 and i am new and have done countless hours of researh .....so please help! i would like a big giant tranny cooler where and witch 0ne should i get ??
is there a certain size i need?
I went with an Earls cooler. It measured 7"H x 13"W x 2"D. Should be plenty to keep my TH400 cool.
B&M also makes an 11x11x1.5 cooler that should be fine as well and is much cheaper to purchase than the Earls.
Dan
Dan
cool someone was telling me about some bus trans cooler ...i would have to buy all the fitting and all that stuff after buying this cooler right 200 doesnt include parts?
what is the trans cooler from b&m everyone else is saying to use?
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by DanZ28
Their 24,000 GVW unit!
The 3.5" thick one will be tough to make fit if you have an AC condenser.
http://store.summitracing.com/partde...5&autoview=sku
this one is 2 inches taller but 10 bucks more!? is this one better then the one that everyone is useing , what is the difference there all a kit correct, are you guys useing an fiffings or the stuff it comes with?
Originally Posted by Z28/2002
A lot of guys on here are running this; myself included
Dan
Here is the descriptions of all the universal coolers from B&M:
70266 - SuperCooler rated at 20,500 BTU 11"x8"x1-1/2" (Racing model doesn't include installation components and has female 1/2 NPT fittings). Can also be used for all fluid cooling needs.
70273 - SuperCooler rated at 15,000 BTU 11"x5-3/4"x1-1/2" (Racing model doesn't include installation components and has female 1/2 NPT fittings). Can also be used for all fluid cooling needs.
70274 - SuperCooler rated at 29,200 BTU 11"x11"x1-1/2" (Racing model doesn't include installation components and has female 1/2 NPT fittings). Can also be used for all fluid cooling needs.
Dan
TondSS
Sounds like you have some money in the car so I would go with the AN fittings and braided lines, its good insurance and you won,t have any annoying leaks.
I run the B&M Hi Tek cooler with braided lines and AN fittings and so far love the setup.
Trans temps rarely get over 150, and 170 is the highest I have seen so far. And thats playin with it in the heat of the day.
Race your car!
I picked up a flex a lite cooler from summit, it's the 7 by 20 by 3/4... or whatever the bigger one is that has teh AN fittings on it. I also got a tranny temp guage to go no my th400 too.. and if I see it getting too hot, I'm sticking a fan on teh cooler next. But, I suspect that it will be plenty big even with some street driving.
where is the cooler from b&m that is 24,000??
Yes, thats a pretty good cooler! I used custom -6 AN lines from the tranny to the cooler, but that cost me about the same as the cooler did and my cooler was $140.
Dan
Dan
hmmm that is weird there is no more 24,000 hmm... so what are the max numbers i can go on the height and width? so 9 inches was the hight correct me if im wrong. thanks
Race your car!
This is the one that I got from summit, I doubt a fan would be needed with it, but could easily be added if need be. I will be putting it where my a/c condenser used to be, seeing as that is going away when the motor/tranny swap is done:
If you place the Cooler on the trans in a good spot, the radiator fans pull plenty of air in, especially if your AC condensor is removed. I have my fans come on accordingly to my 160* T-stat.
I used to run the 15,000 BTU unit when I had the 4l60E in the car and never went above 180* except when at the track doing WOT runs then maybe it would creep up to 190*.
The trans get hotter under load (WOT runs, pulling trailers, etc) more so than stop and go traffic.
I have a TH400 with trans brake now and when activating the T-brake the trans runs much hotter so I went with a bit bigger and better cooler this time around.
Dan
