th350 question...
Old 06-10-2006, 09:46 PM
onestepfurther's Avatar
Default th350 question...
okay i have a 1993 chevy s10 with a 350 in it. right now it has a th350 tranny in it and i want to swap the tranny with something like the 4l60, i want overdrive basically or maybe even a 5 or 6 speed manual. can you guys help me? i need to know waht kind of transmission i can put in it.
thanks for your help...
Old 06-10-2006, 10:09 PM
Restricted User
CAT3's Avatar
For the 4L60E you would need a control box, if they make one...check with TCI they do have one for the 4L80E, also an OD tranny, but much much stronger then the 60E. A dual pattern flexplate, also available from TCI, a converter to match the trans/engine combo (350 engine w/ 60E may or may not take a longer snout on the converter, or a spacer to be used, I'm not sure on reverse engineering). Dipstick to match trans, lokar usually has any and all trans covered, probably want to get the 36" version though, 24" are too short for use on a car..truck I dunno. DS splines are the same...if you have the 9" tailshaft the DS will swap over, if its a short shaft, you may need to have it lengthened, vice if its longer than 9" shortened.
It would be easier and stronger setup to get a Gearvendors Over/Underdrive unit.
Old 06-10-2006, 10:29 PM
thats the thing, i wasnt wanting to deal with all the electrical B.S. with the 4l60e so i was thinkin about something that isnt electric. is the gearvendors unit just a peice that i could bolt on to the th350? or is it more complex than that?
Old 06-10-2006, 11:57 PM
Restricted User
CAT3's Avatar
It bolts in place of the tailshaft, has a cooler with it, and an electric controller, which is pretty sweet setup. Its like the old GM Dimmer switch, or you can get a different type. It can be setup in auto mode, splitting gears as you drive, or you can setup in manual mode and footswitch when you want OD. nothing complicated.
Old 06-11-2006, 12:18 AM
that sounds like exactly whati am looking for. where can i find it? do you have a link for it or a website i can find it on?
Old 06-11-2006, 12:24 AM
8a8mfh's Avatar
Why don't you use a 700R4, it the same geartrain as the 4L60E but it's not electronic.
I had one in a 350 S10 conversion.
Old 06-11-2006, 12:28 AM
one of my friends gave me that idea too, im thinkin about that as well. im just lookin for other ideas right now. the gearvendors units are very pricey and most likely out of my price range.
i also heard that they make and adaptor plate that allows you to use a 5 speed out of a 5.0 or 4.6 mustang with the 350 small block. has anyone heard of this before?
Old 06-11-2006, 06:40 AM
8a8mfh's Avatar
The 5.0 mustangs use a T-5 just like the third gen f bodies, except the input is different, and probably other things. The 4.6 mustangs use a T-45 which is totally different and not worth adapting in IMO.
I used to have a 4.6 mustang, there is a company out there that makes kits to put 700R4's in them, so whoever came up with that thinks the 700 is better I guess.
Old 06-11-2006, 11:43 AM
well i will probably end up going with a 700r4. can i use the same TC thats in my th350 or do i have to get another one?
Old 06-11-2006, 11:49 AM
8a8mfh's Avatar
You'll need a 700R4 converter.
Old 06-12-2006, 12:16 AM
okay... thanks for your help. now i just need to find someone whos sellin a 700r4
