Filter/gasket question
Old 06-13-2006, 05:19 PM
ping2day's Avatar
Question Filter/gasket question
I am getting ready to change the fluid/filter and install my new converter. I went to the store to buy a filter and gasket at an Advanced Auto store and they list two. One for a flat shallow pan and one for a stepped deep pan. Which do i have? Both showed 16 bolts. I did not know there were different pans. Also how many quarts of dexron do i need with a dry converter?
Old 06-13-2006, 05:23 PM
Moderator
jimmyblue's Avatar
Camaros are shallow, unless you do like I did and
swap on a truck pan.
Do not buy a cork gasket type if you have a steel
pan with the ridge; I had a chrome pan on there
that just pressed through and split it over time and
gave me a big ol' leak. If it gets done leaking you
will not have enough juice left, to drive. That's one
reason to like the truck pan & filter.
Old 06-13-2006, 05:26 PM
ping2day's Avatar
They must have it listed wrong. It said Camaro SS 5.7LTR. Thanks I was thinking of putting an aftermarket deeper pan on also.
