Help engine has to rev before tranny catches??
Old 06-19-2006, 01:01 PM
Phoenix64's Avatar
Default Help engine has to rev before tranny catches??
If you put it in gear, there is no foreward rolling like it used to, and then when you hit the gas, the engine has to rev-up before, it feeks like the trans catches, and the car moves.
TC or Pump, or clutches?????????????????
Old 06-19-2006, 01:14 PM
ramair21's Avatar
Sounds like your trannys is about die....
Old 06-19-2006, 02:15 PM
Moderator
jimmyblue's Avatar
Low fluid level will do this. Checked it?
Old 06-19-2006, 02:41 PM
Predator T/A's Avatar
in first gear you have the low/reverse clutches holding and the forward clutches driving which takes alot of fluid pressure....the pump could be getting weak the pressure control solenoid could be bad......does it slip in any of the gears?
Old 06-19-2006, 02:49 PM
Phoenix64's Avatar
Its fine in reverse? Doesn't seem to slip in ny other gears?
Old 06-19-2006, 02:56 PM
so it doesnt do it in reverse
Old 06-19-2006, 02:58 PM
reverse uses an different drum but the low/reverse clutches are still holding sounds like there is a problem in the forward clutch circuit...........
