Poly motor mounts and poly trans mount question.
i dont think it would break from not being able to flex, there are cars that run solid mounts without breaking anything. i would think it would be worse if you had a really hard mount on the trans, and a really soft mount on the engine because the torque would cause the engine to move and the trans wouldnt move with it...
Originally Posted by waterbug1999
Dont care about if it vibrates.. The car is a weekend/nice day/ beat the **** out of it car.
Cool, I just ordered a set of poly motor mounts. I guess we will find out if it breaks anything.
You might want to take a look at this https://ls1tech.com/forums/generation-iii-external-engine/492703-best-poly-motor-mount-write-up-ever-written.html
Originally Posted by Luna
Have fun installing them with the headers on
You might want to take a look at this https://ls1tech.com/forums/showthread.php?t=492703
I guess its a good time to do it.
Originally Posted by spy2520
how much do youg uys think those mounts soften up over time? i'm not scared of vibration but if it dies down a little that would be nice...
I installed the motor & tranny mounts and yeah it vibrates but no worse than the vibrations I get from running 18" wheels with 265/35 and 295/35 tires!! I also did it all with the headers on, no big hassle, I just jacked up the motor a little more and it worked fine. I only have about 500 miles on the new mounts and about 6 passes at the local strip and they seem to have softened up just a bit. Either that or my *** is getting softer, not sure which!!
My prothane mounts shook the hell outta my car at idle for about a month and a half or so until they calmed down, they don't actually rattle anything anymore but they are more noticable. I can't speak for a trans mount.
