STR on converter question?
Old 06-21-2006, 02:48 PM
SRpwred240's Avatar
Default STR on converter question?
My next mod is going to be a Torque Converter and 3:73s , they will be installed around the same time. My question is About the STR what is a good STR on a 3500 stall. I dont really understand what the STR means so I dont want to order a Converter not knowing what I got. The Converter I have been leaning towards getting is a TCI 3500 stall and the str is 2.5:1. My car is not a daily driver but its also not a car running at the track all the time either. I want a converter that is gonna get me going from a stop but I also want 1 to hold its own from a roll 2. I see most guys who post on here have a str around 2.1-2.2. Can some1 explain?
Old 06-21-2006, 03:15 PM
b00sted's Avatar
The higher you go, the looser it will feel. 2.5 is what I had planned on in my 99 Z with a th350. It'll give plenty of punch while still feeling pretty close to stock...But still a bit looser.
2.5 will be good all around, lower than that feels too close to stock and higher than that will start to feel really loose. I think my mustang's is around 3.0 by the feel of it.
Old 06-21-2006, 04:28 PM
2002LS1Z's Avatar
3600 2.5 STR is what I just put in mine which is a daily driver and sees the track every few months.
Old 06-21-2006, 04:42 PM
HD1911's Avatar
I take it is the Yank SS3600?? i just bought one and havent put it in yet.....lemme know how you like it and stuff.
Old 06-21-2006, 04:56 PM
02NBMFormula's Avatar
STR stands for static torque ratio. it is basicly how much a torque convertor multiples the torque as the engine is approaching stall speed.
what this means is that the higher the STR the harder the hit to the tires. so you will spin more with a 2.5 STR than a 2.2
when people say "looseness" they mean how much the convertor slips as it approachs stall speed. the higher the STR the tighter the convertor is.
also, with any convertor, you will lose a slight amount of top end(ex. low dyno numbers on A4 cars) but the other attributes of the convertor more than make up for this.
if i got any of this wrong, feel free to correct me.
Old 06-21-2006, 05:41 PM
SRpwred240's Avatar
Will a converter with the STR of 2.5 still be able to get good traction on some drag radials and cut the60ft time down?Also does your trap speed at the track tend to go down with a converter? Overall do you think its better to get a lower str than 2.5 maybe a 2.1 or 2.2.
Old 06-21-2006, 05:54 PM
2002LS1Z's Avatar
Fuddle
Old 06-21-2006, 07:24 PM
AK's WS6's Avatar
Yeah, with a decent tire and say a 3500 with the 2.5 STR you mentoned you should be able to cut a 1.6 60'.
It depends on the effiency of the converter, but usually you won't drop any mph but some people with PI converters tend to lose a little mph but still turn respectable 1/4 mi times.
If you are really concerned with roll racing a lower STR might be for you (more efficient up top), but it will feel a bit looser than one with a 2.5.
with drag radials it should get good traction with a 2.5 str. also for the trap speed, that depends on how effiecent a convertor is. usually no but there are always those exceptions
Old 06-22-2006, 01:32 PM
SRpwred240's Avatar
thanks for the help! does anybody know if there is a 3500 stall converter out there with a lower str than 2.5? Is there anyway you can customize ur own converter by contacting a converter maker?
Old 06-22-2006, 04:28 PM
i think fuddle will build you what ever you want.
might also try yank
Old 06-23-2006, 04:10 PM
SRpwred240's Avatar
I just emailed Fuddle and TCI to see what they recommend. I told them I want a converter to cut my 60ft times and be able to hold its own from a roll race too, since it seems like most of my races do come from about a 20 50mph roll on the street.
Old 06-26-2006, 07:21 AM
MNR-0's Avatar
I currently run a Fuddle 3400/2.1STR and its about as big as I would want to go for a DD with major city duties. The best all round converter for DD is 3000/2.0 with respectable track performance IMO. Dont go less. On a big-*** GTO like mine add 200RPM flash stall.
Old 06-26-2006, 12:21 PM
SRpwred240's Avatar
MNR-O How do you like the str of 2.1 do you get off the line pretty good with that 2.1str and how does your converter do from a roll race,and if you dont mine me asking how much did you pay for your converter from Fuddle
Old 06-26-2006, 01:25 PM
JSTAN's Avatar
STR stands for Stall Torque Ratio. Basically, STR is torque multiplication. If a car has a higher STR, it will feel tighter on the street because the converter is multiplying the input torque by a higher number. It will also give a harder punch out of the hole. STR is created by two components inside the converter moving at different speeds. Shortly after launch, those components reach an equal speed eliminating STR completely.
Old 06-26-2006, 01:38 PM
kpowr82's Avatar
a 2.5str and 3.73 gears will destroy any tire you throw at it on the street from a dead stop. Some A4 guys get gears to tighten up their converter. IMO, you need to match the str of the converter to your gear ratio.
If you want 3.73 gears, then a 3600 stall 2.0-2.1 str verter is good for you. You'll still get that kick down low with 3.73 and maintain better hp efficiency up top with a 2.0 str.
Old 06-26-2006, 02:01 PM
Roarin_8's Avatar
Don't do a gear change yet, get used to the converter first then if you want, add gears later. You will have severe traction issues if you do both at the same time and are not used to it.
Old 06-26-2006, 05:03 PM
tbick's Avatar
i have a 3600 fuddle with a 1.8 str, it feels a bit loose, but still hits hard off the line and does very well from a roll. im thinking about getting some 3.42's or 3.73's to tighten it up a little.
Quick Reply: STR on converter question?
