how much HP loss from T56 to my TH-400
Old 06-24-2006, 10:12 PM
Mr_president's Avatar
Default how much HP loss from T56 to my TH-400
well as you can see in the sig im putting out around 550 hp. for people who have done the swap, how much HP did you loose.
how much should i expect to loose?
Old 06-24-2006, 10:50 PM
Domestic Demon's Avatar
Probably about 5% more power loss to the wheels than you had with your manual trans.
If you add a stall converter, it will be even more, since they allow for much more slippage.
Old 06-25-2006, 08:15 AM
z28convert's Avatar
My dyno numbers are in my sig. the guy who did my cam swap said that cam in a six speed car made about 400hp/ 375tq.
Old 06-25-2006, 04:04 PM
holllly **** i hope that is not in my case!!
Old 06-25-2006, 06:08 PM
AK's WS6's Avatar
Chances are your results will be similar, but I can only assume you are doing the swap to improve 1/4mi times so if thats the case you might not be very happy with HP #'s but you'll love the 1/4mi times
Old 06-25-2006, 07:51 PM
yep that is exactly why i am doing it so will see!
Old 06-25-2006, 08:01 PM
Richiec77's Avatar
So long as you get the right TC, you'll be fine. The Power #'s on a Dyno never ever tell the whole truth. Only racing it will.
It's hard to say. It more depends on the TC then the trans. The trans is will rob some more power since you are turning heavier part. But that's what it will take to keep the power in the car and put it to the ground.
Old 06-27-2006, 12:06 PM
Race your car!
JL ws-6's Avatar
Friend of mine just did the swap, his car made 497 hp thru the 6 speed and 12 boltw/4.10's, after the swap he made 435 rwhp, but the tq went thru the roof. This is with a loose hughes stll that is stalling about 5000 in his car.
I don't knwo 100% if there's any tuning changes that have to be made for the auto,. maybe a slight tweak for the idle or whatever, but my advise, is do the swap, go to the track first, see what that gets you, and then dyno. This way, when you go to the track and see a massive improvment, you'll be happy, get the dyno # after.
Best part about the dyno #, os that people will ask you what your car makes for power, and you tell them the th400 dyno # and then what the car ran, they'll be like what?
Old 06-27-2006, 01:14 PM
DanZ28's Avatar
Wouldn't really worry about the dyno number, huge difference between an unlocked auto and an M6. Like mentioned before, the results will show at the track. Just be sure to put better wheel studs on there so your tire stays on this time ...
Dan
Old 06-27-2006, 02:10 PM
Dan
OUCH low blow hahaha thanks for reminding me. we have got them on and reasy to go! cool guys
well what do you mean about the tranny being locked or unlocked im new to the auto deal. but i wont have to worry about that right because my tranny doesnt have the stuff the 4l60e does !?!
Old 06-27-2006, 03:50 PM
Race your car!
JL ws-6's Avatar
You mean all the junk that breaks in a 4l60.... no, none of that garbage is in there. I asume you went manual valve body too... also a good move if you did.
Unlocked, means the converter will never lock, so the tranny will always have some slip, but alot of that depends on teh converter you are running, a good effecient converter will have very little slip once up to speed.
Old 06-27-2006, 04:58 PM
hmm i thought the th-400 was always locked up ...
Old 06-27-2006, 05:54 PM
BlackHawk T/A's Avatar
No, the converter lockup is controlled by computer settings and will never lockup under WOT unless specifically programmed to do so, and only under certain conditions.
Old 06-27-2006, 07:01 PM
SLowETz's Avatar
Or.... you can have your A3 set up for a lock up verter(but is pricey). I bought my(rmvb/TB'd)TH400 already built LU ready and can lock it up at will with the flip of a switch. Almost the best of both worlds in a non computer controlled tranny.
Still haven't had the time or *** to install it, but am thinking it will suit my needs well w/the tall gear.
As for rwhp loss..... the example in the above post seems 'bout right..... 12-15% would be my guess, but may vary depending on race weight and rear gear/tire combo.
Old 06-27-2006, 08:15 PM
JMBLOWNWS6's Avatar
I have a 4l80 coming with a 3600 stall and the b&m shifter. Going to add a manual push button on the sixspeed upper console to lock and unlock the converter. I cant wait. I was torn between a 4l80 and a th400. I rode in two cars. One with a th400 and another with the 4l80. It was really nice having the extra OD when enjoying the car and not all out racing.
Old 06-28-2006, 01:28 AM
DanZ28's Avatar
Just giving you a bad time, I know you wouldn't let that happen again .
Old 06-28-2006, 04:37 PM
n2o junkee's Avatar
does any know what the hp loss is from a 4l60e to a th-400?
Old 06-28-2006, 04:38 PM
i hope!
Old 06-28-2006, 11:11 PM
What would be the disadvantage of having the extra overdrive gear?? Seems like nothing but an advantage to me. Both trannies are strong as hell and have similar 1st-3rd gear ratios, so I can't see why anyone would want a TH400 over a 4L80E, unless cost was an issue.
Old 06-29-2006, 04:34 AM
Race your car!
JL ws-6's Avatar
weight.. a th400 is heavy, a 4l80 is really heavy.
Quick Reply: how much HP loss from T56 to my TH-400
