how do lock up converters work with a th400?
Old 06-28-2006, 04:17 AM
Boostaholic's Avatar
Default how do lock up converters work with a th400?
Can I get a lock up converter for my 400?
Old 06-28-2006, 02:16 PM
Yank's Avatar
We sell a lock up kit for the TH400
it has:
The lock-up converter (special th400)any stall
special front transmission pump
billet input shaft
Alum. lock-up valvebody -custom
braided hoses with A-N fittings
wiring plug
call us for more info
Old 06-28-2006, 04:41 PM
Mr_president's Avatar
how much time will a lock up conveter save you in the 1320, compared to none lock up?
Old 06-28-2006, 04:57 PM
Yank's Avatar
That will depend on a lot of different items
how the car is set up
engine power band
weight of car
eff. of converter
some cars will run better, quicker with out the lock-up and a matched converter & drivetrain and other combos with a mismatch of parts might run faster,quicker with the lock-up (higher than needed stall or not enough rear gear will make a larger difference)
But every setup is different, so a guess would not work here
Old 06-28-2006, 07:45 PM
DanZ28's Avatar
How much HP can the lock up clutches hold? And at what point in the 1/4 would you lock up the TC? I would think only at the end 3rd?
TondSS, why do you want a lock up converter?
Dan
Old 06-28-2006, 08:24 PM
I think my main issue with locking up the converter is just driving it around without being at 1000000 rpms going down the freeway.
Old 07-01-2006, 06:20 PM
i dont know i was just trying to learn about it....
Old 07-27-2006, 07:01 PM
GFORCE1320's Avatar
I've got one of Yanks Lock-up TH-400 transmission and converter, I'm dropping it in the car tonight.
Quick Reply: how do lock up converters work with a th400?
