How much hp loss from a 4l60e to a th-400
Old 06-28-2006, 04:53 PM
n2o junkee's Avatar
Default How much hp loss from a 4l60e to a th-400
I am going to a th-400 and I want to know how much of a loss in rwhp am I looking at if any and will there be any gain at the track?
thanks too all that can help in advance.
Old 06-28-2006, 05:03 PM
s346k's Avatar
i don't know if you'd see any gain at the track with a straight swap. the gain would come from the use of your new transbrake.
i would expect the th400 to be a little slower as the 4l60e 1st gear is wicked short and the 400 would also require the use of a little more power to operate.
Old 06-28-2006, 06:20 PM
Race your car!
JL ws-6's Avatar
You can get a 2.75 first gear in a th400, but it's big dollars to do that.
In the long run, the Th400 will be substantially faster, simply because all the $ that you would have blown rebuilding the junk 4l60 can go to other things that will make a differennce, rather then just replacing a worn out part.
Old 06-28-2006, 07:32 PM
n2o junkee's Avatar
does anyone know how much it is to do this and is 2.75 the gear that is in the 4l60e?
Old 06-28-2006, 08:53 PM
Race your car!
JL ws-6's Avatar
The 4l60 has a 3.08 if I remember correctly for 1st gear, and to have that gear set put in a Th400 you're talking about anoher 800 bucks if I remember correctly. I think that instead of having a 2.48/1.48/1.00 gears, it will have 2.75/1.75/1.00 gears. There's other sets also available, but most people wouldn't go to that gear ratio because if you're running the th400 for it's strenth, you're probably making enough power to warrant it, and the longer first gear helps "calm" the car down a little on launch over the shorter 1st gear, also helps decrease the wheelie action some over the short gear.
Quick Reply: How much hp loss from a 4l60e to a th-400
