TransGO with stall or no???
Old 07-02-2006, 10:50 AM
MidwayAvenue's Avatar
Default TransGO with stall or no???
i'm trying to decide if i should go and get a transgo shift improver kit and put it in when i put my stall in...
i've read some problems about the transgo kit...anyone have any thoughts i should do...should i get it or not and why
thanks for the help everyone
Sean
Old 07-02-2006, 02:17 PM
FLT
FLT's Avatar
I would do the sk with the stall. You'll love it.
Old 07-02-2006, 05:20 PM
SRpwred240's Avatar
Im gonna do the trans go with the stall might as well while the transmission is out.
Old 07-02-2006, 05:33 PM
AK's WS6's Avatar
No problems here. I love it!!
Old 07-02-2006, 06:57 PM
05_GTO's Avatar
Might as well weight till you do it with the stall IMO.
Old 07-02-2006, 08:27 PM
Jake the SSnake's Avatar
I bought the kit with my stall but never got to install it unfortunately.The stall really softened my shifts up and nothing sucks more than a soggy shift.
Old 07-02-2006, 10:37 PM
SCREAMIN's Avatar
Stall, transgo and tranny cooler and you should be good to go
Old 07-07-2006, 09:57 PM
BlackHawk T/A's Avatar
I would definetely recommend it.
Old 07-07-2006, 11:09 PM
Kraest's Avatar
I've heard bad things about shift kits + increased computer-controlled line pressure prematurely exploding the sun shell.. Lemme see if I can find it.
Mike
Old 07-08-2006, 10:35 PM
AK's WS6's Avatar
Mike
With a shift kit you should leave the line pressure settings alone
Old 07-09-2006, 12:31 PM
so what should i tell the guy when he installs the shift kit..is their a certain procedure or set-up when installing it?
thanks
Old 07-09-2006, 03:34 PM
AK's WS6's Avatar
Well, the kit I purchases from Pro Built had some revamped instructions per his recommendations, basically drilling out a couple larger holes in the valve body. Other trans go kits might have this stuff, but i'm not really shure, if not it's really not a big deal. The one main question you have to answer is how hard you want it to shift and this is basically decided on # of washers installed (1-3) 1 being mild 3 being hard. I went with one washer per PBA due to it mostly being a street car and others also like one washer for street/strip vehicles.
Old 07-09-2006, 10:07 PM
HD1911's Avatar
i have 3 washers (transgo) in mine and it is a Daily Driver...dont regret it at all.....have a 3600 also
Old 07-09-2006, 10:30 PM
3 is overkill IMO, 1 is enough from what i've read.
My .02
Old 07-10-2006, 02:11 AM
HD1911's Avatar
to each his own i guess
Old 07-10-2006, 07:31 AM
koolaid_kid's Avatar
I agree, everyone has their own opinion.
I went with 3 because my STS was making the trans slip A LOT during shifts. Now shifts no longer slip at all. During partial power (normal) shifts, it feels just like stock. Best of both worlds, IMHO.
