Detonation After Tranny Swap
After I swapped the 6-Speed my car ran fine for a short time but then it fouled or burned a set of spark plugs and began to detonate or "ping". I put a new set in and pulled some timing and it did the same thing. The knock sensors are working and it is not running lean but on the rich side. Why is it detonating or why is the computer advancing the spark so much? Is there anything with the wiring that goes from the computer to the coil to the spark plugs? Does something need to be grounded or a circuit closed? Any ideas?
Thanks
Thanks
Thanks
Thanks
Originally Posted by 408WS6
Are you sure its not getting false knock? Did you use a polyurethane mount for the tranny? I've heard those can cause false knock and set off your knock sensors. just my .02
you got a cam in the car? could be the converter too tight for the combo.
like flooring the car down low in 5th gear or something with a 6spd. loads the motor and causes detonation.
good luck.
