Two turbo 400 questions?
Old 07-09-2006, 05:31 PM
DAPSUPRSLO's Avatar
Default Two turbo 400 questions?
One: How much transmission fluid are you guys with th400s, deep aluminum pans, 9.5"ish converters, and tranny coolers running?
Two: My th400 from transking has a transbreak. It is not wired at the moment. I've currently got 7 quarts of fluid in my setup but my dip stick isn't worth a damn cause I had to bend it up quite a bit to fit and it doesn't read right. Is it possible that not having the trans break wired is causing the trans to not move when reverse is selected or does 7 quarts sound low. Was going to call transking tomorow to verify.
Thanks.
Old 07-09-2006, 08:28 PM
xssive's Avatar
Yeah you have to have the car in neutral ( or reverse depending on manufacturere) and hit the trans brake to make it reverse. The trans brake causes first and reverse to be selected at the same time...
Old 07-10-2006, 01:31 AM
revtime's Avatar
Not all Transbrakes work that way but alot do.
I have a Rossler TH400 RMVB with TB and I don't have the brake hooked up but reverse works just fine.
I bet if you hook up the Tbrake and engage it when you select reverse it will work.
Old 07-10-2006, 06:33 AM
DAPSUPRSLO's Avatar
Thanks guys. Any comment on the ammount of fluid you've put in your trans and other trans parts?
Old 07-10-2006, 12:01 PM
Race your car!
JL ws-6's Avatar
Eastside told me the hughes unit I have takes about 10 quarts I do believe.. don't ask me what size the converter is tho... give transking a call, ask them. I'm sure they can tell you how much fluid is supposed to be in it. Mine as well inquire about the transbrake question too.
Old 07-10-2006, 03:07 PM
DanZ28's Avatar
The TH400 itself holds 6 quarts. Then you add for the deep pan, converter and cooler, so 10 quarts sounds about right. I would buy a new dipstick and be sure...
Dan
Old 07-11-2006, 07:03 AM
DAPSUPRSLO's Avatar
Transking indicated 9.5 quarts and that I need the transbreak for driving. Thanks a ton guys for the help and suggestions though
