Hate to admit this, but you guy's were right...
And I was wrong.
'Bout 6 month's ago, i went shopping for a converter, so I asked for some advice from you guy's.
Told you all about my car, the 2.73 gear's, tire's I had, etc.
Almost everyone on this site said go with a 3500 stall. A couple said go bigger, couple said go smaller.
The one's warning me away from the smaller stall I was considering,[3000], said that in a few month's I was going to regret not getting a bigger one.
But noooo, i thought I knew more then everyone at LS-1 Tech.
Well, turn's out that i wish I'd have gone bigger.
Don't get me wrong, I love my stall.
But I just keep thinking I left a couple of 10'ths on the table by not stepping up to the plate.
Should have listened...
Z28LS1camaroguy do not go with a 4000 stall, you will regret it. Go with a 4400. It rocks the **** out of any stall setting you could get. With a stock cam right now and 2.73s the 4400 stall is amazing. It drives around town great and will only impove performance wise with ANY cam selection I make. There is no difference in drivability between a 4000 stall and a 4400 stall, only differences in performance. If you are going with a 4000 you obviously have no interest in N20, so go with 4400.
And dannyz, yea, that sucks. Sorry to hear that. I would just get some 4.10 gears (or 3.90) and run a 27in or 28in tire and a hefty 150 shot of N20. I am not a fan of N20, but with a stall that low you could run a 150 shot off the line and probably have it flash up to 4k, maybe a little higher. With some sticky rubber those 4.10s and that stall will have you out of the hole like a bitch on fire and the taller tire will help your rpms at the end of the track (and on the HW).
Originally Posted by kruthes1
You should call John at Fuddle, I bet he would take care of you on re-stalling your converter.
A long time ago, before I even joined ls1 tech, guys at the other site used to tell me the ol rule of "find the stall speed you want and go one step bigger". Wanted a vig2800 and went with a vig3200. BTW, all PI converters are under rated and flash between 400-600 rpm higher than labeled.
