converter install..
converter install..
anyone done a converter install on jackstands in there garage? im on a budget and have money for converter but not labor. i am somewhat mechanically inclined and my father will be assisting just curious what im looking forward to?
That site was very helpful and informative but what about if the engine and trans are out of the car?
Can I simply bolt the converter to the flywheel and then mount the trans to it? Having of course marked the keyway so that when I mount the converter it will be in close position of the key way and will only require a slight turn on the tailshaft.
NOOOOOOOOOOOO!
I have done numerous tranny swaps with the car on jackstands. Make sure you have a good selection of tools and alot of patience. A transmission jack comes in handy but I have always used a regular floor jack and never had a problem, its all in the balancing act.
2 guys should handle it no problem.
And don,t ever mount the converter to the flexplate first........never.
Fill converter with at least 1 quart of tranny fluid (I put 2 in a dry converter) and install making sure it is seated all the way in.........let me say that again. Make sure its seated all the way. This can be tricky so double and triple check yourself.
Once you have done this a few times it gets much easier and faster. I installed my TH400 in about an hour.
Yes thats true with the turbo 350 and 400 but the 4L60E doesn't have a flywheel cover like the t350 and t400 thats why I was wondering if the converter gets bolted up first. This is my first 4L60E converter install. The engine / trans are out of the car and can be assembled along side it and then installed as it is going into a 69 camaro and doesn't have to come up from the bottom side.
Let's see....
Stock bolts are way longer than the ones you need.
You will need at least 4 feet worth of extensions and some swivels.
Loosen your y pipe connections only, no need to remove them if you don't want to.
It sucks but you save hundreds of bucks.
You get to say that you did it.
Originally Posted by blind527
Do you guys recommend getting a new flexplate with a new converter?
I think I paid 80 bucks for my B&M.
Originally Posted by mcowart
just be patient with the fly wheel bolts..they are a pita as i came to find out i couldnt get them out so it has to go to a shop...
ya i didnt have access to all that fun stuff..i get in trouble for the tools i have now..they take up too much space..and yes i meant they flex plate not the fly wheel..dunno why that came out..
I just finished installing my tranny yesterday. Get a really long entension (I think mine was about 36 inches) plus have a 12” on hand just in case. I used the extension to not only get the top bell housing bolts out, but also to get the converter unbolted from the flexplate. Just rotate the engine so that the bolt in the flexplate is exposed near the starter, stick the extension in, and use an air ratchet to unbolt it. It’s a breeze. The bolts on top of the bell housing are alittle more challenging, you gotta unbolt the tranny crossmember down and tilt the engine down and reach up in there with the long extension. I unbolted my shifter and went through the hole where the shifter goes with a long entension to get the top tranny bolts. It wasn’t that bad. I found that using swivels was very awkward and frustrating. The job will feel 10x easier with an air ratchet if you don’t already have one.
Also, when you install the new converter into the tranny, and then the tranny to the engine, make sure there is at least 3/16" gap between the converter and flexplate before you bolt the two together. If there isn't at least 3/16" gap and you cant rotate the converter by hand, something is wrong.
If you don't have all the right tools and not willing to invest in them, the $350 doesn't sound like a bad deal.
