I have the wrong 4l60e
I just bought a 94z28. I was told the trans was out of a s10 4.3l. I think its a newer on becouse the bellhousing is removible. The problem is the VSS wont plug up. You have to manuly change gears and it wont go into 4th. I thing this is becouce the VSS is not hocked up. And what would it take to get the VSS to work. I thing I will have to change the tail housing and put the right sensor in it.
Thanks in advance.
Thanks in advance.
