Advice: Need a little help with my shift points and O/D on my new set-up
Hey all:
First I have a 2002 Camaro with all the Bolt-ons, Heads & Cam, fully built trans ( Close to a Rock-On type trans ) with a Fuddle stall with a 2.1 STR. My old set-up was with a TCI 3,200 stall with a 2.0 STR amd the stock trans and the car whould pull hard at ANY MPH I hammered it at.
What the car is doing from a ROLL: Anything under 15 MPH and when you hammer it the car drops to first and pulls like it should.
Now from anything over 20 MPH the car drops a gear and does not pull that hard at all.
Also it is going into O/D between 38-40 MPH
Do I just need to move the MPH up when it goes into over drive? If so what would be a good MPH? I was think around 60 MPH or so.
Any advice would be much apperciated. Thanks
at full throttle mine doesnt shift into OD until around 130 mph...shifts to 2nd somewhere between 40-50, shifts to 3rd somewhere between 85-95, shifts to OD pretty high up...thats on a pretty much stock car although i doubt your shift points should be much different except for the fact that you have different gears...
