Trans brake on 4l60e?
Old Drag Racer
Originally Posted by 1984camaroz28
im looking to go mid to low 9s on bottle not shure if it will hold up
Old Drag Racer
looking to stay with a OD trans......maye stay with my t56 if a 4l60e cant hold up
You definately should not be looking at OD transmissions with a goal like that. If you have a lot of money to throw around look into a built 4l80 or using an overdrive unit on a th400.
If you were turbo you could run 2.75 gears like I do and not have a need for overdrive. I'm pretty sure a 2.75 gear wouldn't work as well on your setup as it does on mine.
My goal is mid 10's with my car. Why does every always say they want 8.xx or 9.xx. Most don't realize how fast that is. My car traps mid 120's and even though i'm use to the car it still feels fast every time I get on it, just doesn't scare me (until I up the boost again, then I get a week of being scared until i'm use to it again).
you can build a 4l60e to handle that 9 second run but its gona be hard on the res tof things with a good stall to hit your goal. and most of these guys are right 9 seconds is fast and not the most efficient street car haha but it can be done just shop around and youll find what you need.
