Tranny fluid spilling from pigtail plug(wtf?)
Old 07-27-2006, 06:01 PM
Daez's Avatar
Default Tranny fluid spilling from pigtail plug(wtf?)
So, my tranny was low on fluid, and I found out that it is spilling out from the top at the spot where you plug the pigtail in(the cord with like 8-10 wires).
I didn't know that spot even had a connection to where the fluid is, how does that work? anyone know how I can fix that?
Old 07-27-2006, 06:03 PM
Predator T/A's Avatar
yep get a seal and pop the plug out from the bottom and replace the seal around the plug....got to take the pan off aftyer the pans off takes about 45 seconds
Old 07-27-2006, 06:05 PM
i could send you the seal if you cant get one from a tranny parts dealer.....i have about 200 of them lol.......just pm your addy and i will send it they cost like 15 cents lol.....i should say the only place you will get one just the seal is from a tranny parts distro
Old 07-27-2006, 06:11 PM
Daez's Avatar
excuse my lack of knowledge on this part, but if I take the pan off, will I need seals for the pan itself? and I have decently dexterous fingers, and can reach inside that area without removing the pan, so would that work, or do I for sure need to take it off?
Old 07-27-2006, 06:19 PM
well the pan has to come off becuase you have tabs on ther that have to be pushed in...i will send you a gasket also they only cost me 97 cents....but you may as well change the filter also
Old 07-27-2006, 06:25 PM
what year car do you have also
Old 07-27-2006, 06:44 PM
Daez's Avatar
I have a 94 z28
Old 07-28-2006, 11:39 AM
yeah you are best to pull the pan off i doubt you will be able to get your fingers inside the case to be able to stretch an o-ring seal around the plug i never have....i will send out the package tommorow...
