Can you fill the TC with fluid...
While still intalled on the car? What if I just turn the engine over with out starting it? Or using one of the cooler lines?
Thanks,
Dan
Thanks,
Dan
I don't understand, how would I knock out the front pump? It would still work just like normal whether the TC has fluid in it or not right? The pump pick up is in the pan full of fluid, will turning the engine over be good enough to prime everything or will the engine have to run before the pump starts working?
From what I understand, the time spent cranking the motor to get fluid to the convertor, something can happen to the seals or something up there. I've always put a quart or fluid in the convertor before i install it that way I won't have any worries.
Originally Posted by StormT
The pump is a vane pump it needs the momentumme to pump anyway don't think you could pump it fast enough. Why do ya want to do this ?
Dan
You can try it, but even on Monster Garage when they forgot to fill the convertor for the Iraq build it cooked the tranny. The guy that did it said he puts them in dry all the time, I would never put one in dry. My luck it would damage the tranny as well. If you call these guys and they say it's ok, what happens if it's not. They'll be like we never had a problem, sorry! Then your stuck with the R and R anyway, plus what it could cost to fix.
They feel pretty confident it will be fine. They just said to make sure I dump about 8 quarts in first. The pump will fill the TC instantly. I'm still gonna check around a bit more for some professional opinions though so I may still be pulling this thing out. This is like my 5th TC install but only the first time I forgot to add fluid to the TC .
Dan
Dan
