Flushed my trans fluid this weekend...
Old 08-08-2006, 09:59 PM
Bad30th's Avatar
Default Flushed my trans fluid this weekend...
Bought 14 qts of Castrol tranny fluid... Measured off gallons of water inside a 5 gal bucket with a marker using an old gallon-size water jug.
Took the trans return line loose and twist-tied it to the bucket handle to point it into the 5 gallon "calibrated" bucket. Started the car and pumped the fluid into the bucket while pouring new fluid into the dipstick tube. I could only get just over a quart into the dipstick tube before about a gallon would pump out so I'd turn the car off and add 3 more quarts, then start it up again, etc.
Right at the end of the 4th gallon it started to pump clear/new fluid, so I turned it off and dumped in the last 3 quarts (2 left over for next time).
It seems to have a smoother ride and smoother shifts, and it's good to have fresh new fluid in there. Thanks to joecar and others here for the suggestions and ideas.
Rob (Bad30th)
