trans cooler install
Old 08-10-2006, 08:15 PM
my number 1 hater's Avatar
Default trans cooler install
I am going to install a trans cooler this friday on my 98 Z.. I think the outlet is on the bottom of the radiator AM I RIGHT??????
Old 08-10-2006, 08:34 PM
chewy99ws6's Avatar
it is the line that has the clamp on it, I think the top one is the outlet.
Old 08-10-2006, 09:31 PM
MonsterZ28's Avatar
where do you mount one?
Old 08-10-2006, 10:03 PM
chewy99ws6's Avatar
I mounted mine in front of the radiator, but you can mount them anywhere you want
Old 08-11-2006, 12:00 PM
i need to know for sure Otherwise the cooler will not do the job RIGHT...
Old 08-11-2006, 12:13 PM
LSWon00's Avatar
Un hook both lines and crank it up....you'll find out by which line the fluid comes out of. As soon as it starts pumping shut the car down. You may only need to start the car for a few seconds.
Old 08-11-2006, 12:17 PM
chewy99ws6's Avatar
I looked at might this morning and it is the top line, that is the line that has the clamp on it, the other line has like a swedge on it. hope this helps.
Old 08-11-2006, 06:24 PM
I have used that way before...BUT the trans is not on the car.....
Old 08-11-2006, 06:25 PM
I have used that way before on my monte carlo ...BUT the trans is not in my Z28.....
Old 08-11-2006, 06:29 PM
did u put your trans cooler on ???? or did a shop do the work??? i have people telling me its the top and i have people telling me its the bottom.
Old 08-15-2006, 09:03 PM
Fabian's Avatar
****, I just did mine and I dont remember. And I cant go look either because my car is about an hour away
Old 08-15-2006, 10:41 PM
chewy99ws6's Avatar
I installed it myself
Old 08-16-2006, 01:34 AM
2002_Z28_Six_Speed's Avatar
I have seen written documentation by GM which states the oppisite of what was said in my Hayden instruction manual. I don't think it really makes a huge difference in the operating temp.
Old 08-16-2006, 01:54 AM
00cls1camaross's Avatar
there are 2 lines... 1 has a ******* clamp on it... it is that line
Old 08-16-2006, 10:52 AM
chewy99ws6's Avatar
yep like I said the one with the clamp
