tranny temps
Old 08-11-2006, 10:16 PM
GT Griller's Avatar
Default tranny temps
Now with my 3400 stall i cant cruise for more than like an hour or my tranny is runnin 210 or so. I have a 22,000 GVW cooler on there but it doesnt seem to be working, would 2 coolers do much better? I have another 18,000 GVW cooler in the garage.
Old 08-14-2006, 08:22 AM
Ouija's Avatar
Do you have the GVW and stock trans coolers both hooked up?
If you have both hooked up the fluid should go into the radiator/trans cooler first, then the GVW afterwards.
The Radiator operating temp is usually 210* so if you flow through the GVW first, then when it hits the radiator, it will actually heat up the temps.
This is why it's supposed to go stock/radiator, then aftermarket cooler, so the aftermarket can further cool the temps.
Many people reccomend bypassing the radiator/stock transmission cooler completely and running only the GVW.
You also need to make sure that where you mounted your GVW it gets good airflow.
Old 08-14-2006, 12:27 PM
GT Griller's Avatar
Yea its mounted in front of the radiator so that it catches alot of air, yea it runnin thru the radiator first then the other cooler.
Old 08-14-2006, 12:44 PM
99Hawk262's Avatar
Try the second cooler and tell us what happens. I am going to run a second cooler as well since I hit 210 on really hot days in the city or after WOT runs. Normal cruising is 180 with my setup.
Old 08-16-2006, 01:40 PM
GT Griller's Avatar
well i got it all hooked up, i bypassed the radiator and just runnin it thru the after market coolers and it runs SO MUCH cooler, i definately recomend it if ur having heat problems.
